Question about Acer Aspire 5600 Series 5630-6951 Laptop
Acer5630 unable to boot
This acer 5630 i bought it 1 year back.it goes off automatically when battery is full.and i have to turn it on.now it s is showing a blank sceen.when i switch on i can see the green light on but blank screen.i mean unable to boot.
looking for a solution
thanks
kumar
I have a similar problem with my acer 5633(same machine differentgraphics card) I accidentally told it to hibernate instead of shutdown. Now the on light and the dvd busy light illuminate and stay lit,The fan runs for a few seconds then it shuts off and thats it, nothing onscreen and no hard disk noise a big fat zero. No P.O.S.T. No boot
  • barmysod Apr 21, 2008
    tried that
    No as the hard drive doesn't spin up I don't think that there is a lot of point in trying an external monitor.I have also tried starting the machine with no hard drive to see if will try to start and give me an error message and I have also substituted the ram to see if that is causing the problem.I have a feeling this is destined for silicon heaven, which I'm not pleased about as it is only 3 months outside warranty.
  • 61 Answers
Try it without the battery
Posted on Apr 21, 2008
  • niall ginnity
    niall ginnity Apr 21, 2008
    just a thot try holding down the fn key and taping the f8 or f4 key this is for the vga external port at the back 1 for laptop screen 2 for external port and 3 for both. have you attached an external monitor to this laptop?
How common is the acer5630 screen going blank and hard to start?
Check RAM/ memory module and clean the connector with pencil eraser. To do that you have to open rear door using screwdriver. If it doesn't work, replace it with the good one that works.
Jan 03, 2015 | Acer Extensa 5630-6806 Notebook
I have a acer aspire 5630, i am tring to reinstall windows and drivers back to factory settings however dont have any discs ut i do have a vista registration number on a sticker on the bottom of my...
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Feb 06, 2011 | Acer Aspire 5630 Notebook
Deleted anti virus programm now my internet dont work i also forgot my password (acer5630)any help available
try going on through Internet explorer...if possible u can then find or request a new password to your ISP
Dec 09, 2009 | Acer Aspire 5630 Notebook
Acer5630 very slow
ok this is what you have to do,,,,rescan your computer for viruses.., download ccleaner, spyboot search and destroy, atf cleaner...restart your computer hit f8 to go to safe mod go to safe mode rerun all this programs in safe mod, clena everything what is bad ( it will be highlated) run disk defragment, restart your computer and let it boot normaly... it should run faster, if you can go to safe mod do all this in normal mode, after all of that got to run and type msconfig it will show you on startup tab what programs are loaded on startupo of win xo uncehc those that you don't want or those that are suspicious to you.... and post me back if you ancourted any problems ....
Nov 08, 2009 | Acer Aspire 5630 Notebook
Acer Extensa 5630 not booting
i would check to see the procesor is seated correctly and make sure there is some goo under the processor fan to make sure it is cooling ok if that doesnt work maybe the board is bad
Jul 21, 2009 | Acer Extensa 5630-6806 Notebook
Hello
Visit this website to find the drivers:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394
Feb 22, 2009 | Acer Aspire 5630 Notebook
Aspire 5630
The only thing you can do is buy a new battery. The normal life of a battery is around two years. If it is used on a more regular basis it will not last as long. So don't feel bad it was nothing you did but the only way to fix it is to replace it they are not hard to find just type in the model in a search box I.E. Google Here is what i found
Dec 29, 2008 | Acer Aspire 5630 Notebook
remove your battery and on your system other wise reinstall the os
Mar 06, 2008 | Acer Aspire 3003LCi Notebook
I need setup my acer5630 idont have cd motherbord or buckup
so youre trying to start afresh?
so borrow a friend for his windows disk and on the bottom of your laptop you should have a windows key. it will have this format:
xxxxx-xxxxx-xxxxx-xxxxx-xxxxx i just read mine and copied it down in the letter x
hope this helps,
Maxicube
Feb 03, 2008 | Acer Aspire 5630 Notebook
Acer 5630
That's weird. can you check that you have the proper timezone settings under "date/time settings" and that your system is not automatically syncing itself through the "Internet Time" tab?
Oct 29, 2007 | Acer Aspire 5630 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
