Question about ASUS Computers & Internet
Asus vw246h monitor screen is all blurry and distorted on bios and boot up, then fine and clear when in windows
  • Joel Rodriguez
    Joel Rodriguez Jul 20, 2010
    have you tried re-flashing the bios or a newer version ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 848 Answers
Asus vw246h monitor screen is all blurry and distorted on bios and boot up, then fine and clear when in windows? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
5E 0NC02 001 4H 0NC02 A01 ASUS 5E 0NC02 001 Power Supply Backlight...
Posted on Jan 12, 2015
  • 128 Answers
You need to upgrade your bios
Posted on Jul 24, 2010
Why is my screen green?
you may change the connection cable
Aug 18, 2015 | ASUS VW246H 24 Widescreen LCD Monitor,...
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red
Have a asus vw246h monitor will turn on and show asus and no signel and then no screen and power light goes red? This trouble maybe power supply or inverter boards is defective.
Apr 07, 2013 | ASUS VW246H 24 inch LCD Monitor
I'm getting a "e<" error
I'm getting a "e<" error? This trouble maybe power supply or inverter boards is defective.
Sep 08, 2011 | ASUS VW246H 24 inch LCD Monitor
Asus Ee pc screen is half white. how can i fix it?
Try to boot to the BIOS screen/ system setup screen. Tap on F2 on the splash Asus splash screen. If the BIOS still shows this problem, it is a hardware failure. You will either need to replace the LCD screen of the video card of your laptop. To further isolate the issue, you need to connect an external monitor on the portable system while you are on the BIOS screen and press on Fn+F8. If the issue is seen on the monitor, then it is the video card, if the external monitor is clear, then it is the LCD screen.
However, if the issue does not occur in the BIOS, it must be the video card. Hopefully it is just a corrupted video card driver. Try to uninstall and reinstall the video card driver. If it does not resolve your issue, then it is the video memory of your computer. You still need to spend some money to have it serviced.
Jul 02, 2011 | ASUS Eee PC 900HD Netbook
Asus VW246H monitor has backlight problem. I hooked VGA up to laptop and the monitor turns on but then 2 seconds later it goes very dim. how do i change the backlight settings?
how do i change the backlight settings? This trouble maybe power supply or inverter boards is defective.
Mar 29, 2011 | ASUS VW246H 24 Widescreen LCD Monitor,...
New asus vw246H monitor. the volume only goes down. how do I bring it back up?
New asus vw246H monitor. the volume only goes down. how do I bring it back up? This trouble maybe power supply or inverter boards is defective.
Oct 30, 2010 | ASUS VK222U 22" Monitor
When I turn on my computer the monitor remains dark unit after about 10 mins then I get the windows desk top. If I shut down the computer (normal shutdown)then restart I get the normal startup...
Try connect your monitor to some other box and try if it works the same way or as a normal pc boot. If it works well with other box, the issue is with the BIOS. Get the BIOS flashed with the latest version of flash program for the Bios chipset which your board is using. If the monitor shows the same symptom on a different box too.. you may need to get your monitor repaired. Good Luck
Feb 14, 2010 | ASUS P5PE-VM Motherboard
HP L1710 has ghost images and is blurry??? Any ideas?
Issues with distorted or blurry images normally happens of two issues.Either a graphics card driver issue or a hardware issue. Hence we need to isolate and verify where would the issue be.
Try going to BIOS, (to enter BIOS, usually you have to use the F1 or F2 or F5 or F10 or ESC or Del key, depending on the manufacturer option. If you are not sure which key to use, then shut down the computer and restart it, The moment you restart it, you will find an option like, "Press F10 for setup" something like that. the word "setup" usually refers to BIOS, note, this will be displayed only for few seconds) Hence press that key, while booting up and that will take you to BIOS, Please check if the issue persist on that screen. If the screen still persist on BIOS, its a monitor issue.
Else, that will be an issue with graphics driver, we can try updating the graphics driver
Dec 23, 2009 | Computers & Internet
I have just bought an ASUS VW246H - has slight ghosting
I have just bought an ASUS VW246H - has slight ghosting? This trouble maybe power supply or inverter boards is defective.
Jun 16, 2009 | ASUS Computers & Internet
Vertical lines at BIOS splash screen
Is your power supply rated to hand the board and the graphics card and all the other hardware?
Did the issue star with the video card?
try removing the extras like the CD drive and any other PCI devices and just putting the graphics card in and whats needed to boot the computer.
Also, reseat the graphiocs card.
also try installing just the drivers for the video card without any of the over clock software.
Try resetting your BIOS by disconnecting the power cabel and removing the BIOS battery and waiting a minute, put back in and restart/
Feb 03, 2009 | ASUS EN7600GT/2DHT/256 (256 MB) PCI...
Computers & Internet Logo
291 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
