Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Metal strip between refrigerator and freezer door is hot
Unplugged refrigerator and after a few minutes plugged in in again; hot strip cooled but in about 15 minutes got hot again.
Repeated this process three times.
Coils are vaccumed clean. Fan seems to run constantly. Vacumed around the fan. Fan motor is hot but not too hot to touch.
hot strip gets too hot to touch - even the rubber seals are too hot to touch.
5 Suggested Answers
  • 125 Answers
SOURCE: front metal piece that the seal goes against - between freezer and fridge
clean the coils under the ref, and check the condensor fan, in back of the unit behind cover on bottom by compressor. replace fan motor if not running.
Posted on Jul 19, 2008
  • 958 Answers
SOURCE: Whirlpool refrigerator side by side door seal very hot
when you said fans working....does it include the condenser fan? or it may have two evaporator fans..
if condenser fan is working, then it is just normal. if the compressor is running, that part would really heat up. and if it is too hot, then the condenser fan could probably not running.
its not constant because the compressor cuts off when ever the thermostat cuts off.
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: The fan is running, but the refrigerator and freezer are not cooling. We cleaned the coils... any other suggestions?
Check the compressor and the relay. Make sure they are working when you turn on freezer and fridge to the max. If the compressor does not start then you need a new relay. If the compressor starts then it is your thermostat that has gone bad and must be replaced. you can find the parts on repairclinic.com and order them with instructions on how to remove the bad part and install the new part
Posted on May 20, 2009
  • 212 Answers
SOURCE: The strip of metal between the refrigerator door
could have a restriction in coils. not bad enough to effect cooling but not letting unit to cool of properly from coils
Posted on Jun 22, 2009
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
My Samsung refrigerator freezer model RB1955SW is not maintaining cold temperatures. The refrigerator is about 45 degrees while the freezer is 12 degrees. The bell that reminds you that the door is opened...
My fridge turns on when it's plugged in but shuts off hours later for some reason and looses cool temp. I unplugged and plugged in the fridge again and it worked but shut off again hours later. What's with that?
Dec 17, 2009 | Samsung RB1955VQ Bottom Freezer...
Kitchen Aid #KSCs25INSS01: Outside of Freezer is very hot, jumped down to -15 degrees - will not allow readjustment.
I recently had the same issue of the sides/center becoming hot on my kscs25inss01. The cooling fan would not come on. I kept unplugging and waiting for a while then re-plugging in to get the fan to work for a while (it would run about 12 hours then get hot again, it also takes 7 minutes for fan to come on after plugged in). I also placed a small box fan at the rear vent pulling the air out. I ordered the contoller board and replaced it, now, the fan comes on and it is staying cool.
Replacement:
I removed panel in lower back,
removed inverter box next to compressor,
removed gounding wire on frame,
then removed the controller box - metal box along side of refrigerator
Popped out old board ,
moved the center jumper from old board to new board in same location,
and plugged everything in and sealed it back up in reverse order.
May 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Both Freezer door and cooling door and a metal strip were hot
That is a good thing. you want that to happen what it does is it avoids condensation to form around the doors
Apr 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Error Code ER FF
FF is your freezer fan. You may need to defrost the unit.
Feb 28, 2017 | LG French Door Cabinet Depth Refrigerator...
Strip between freezer & fridge
light falshing is normal, the strip between being hot is not though, remove the kickplate from under refrig and vaccuum the coils, pull unit out and clean behind, while there make sure that the fan adjacent to compressor is running(when compreessor is on). clogged condensor =hot mullion stip. not a major problem
Mar 02, 2008 | Kenmore 51252 / 51254 / 51259
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
