Question about Kenmore 75085 Air Conditioner
A/C does not cut off automatically any more.
When a temperature is selected, the a/c does not cut off when that temperature is reached. Could this problem be causes by the timer on the remote, or the thermostat in the AC?
  • Kenmore Master
  • 43,501 Answers
Sounds like a thermostat problem...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Why does the unit keep on switching off after running for 2 minutes
Do not know what brand or model your aircon unit is? Sounds as if the temperature you want your unit to run at has already been reached. You need to follow these steps:
- select the temperature you want
- select the icicle icon for cool or thermometer icon for hot.
- select "auto" for your unit to cut in, or to cut off to keep your desired room temp.
For example - hot day 26 degrees and you want the temp in the room to drop to 19 degrees - the unit will shut off once it reaches 19 degrees if it is set to "Auto". Hope this gives you some clues to get it working. Please tick my this helped me box if my tips work. Good luck Gerri.
Nov 27, 2015 | Heating & Cooling
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Can't increase the heat on the thermostat
Instructions1 On nearly every Honeywell thermostat, the heat setting can be increased by simply pressing the HEAT option or AUTO and using the arrow keys to adjust the setting higher or lower until the desired temperature is reached.
2 To set an automatic heating schedule for Wake, Leave, Return and Sleep, press the SCHEDULE button, then EDIT.
3 Select the current day and use arrows to select the time and temperature for Wake. For example, if you typically awake for work at 6:00 a.m. and want the heat to come on, use that as your Wake time and adjust the temperature to suit.
4 Select the day and use arrows to select the time and temperature for Leave. Since you will be leaving the home empty for several hours, this setting will allow the thermostat to lower the heat until your arrival back home.
5 Select the day and use arrows to select the time and temperature for Return. This is the time and temperature that you will choose for returning home from work and may want the heat on to warm the house for your arrival.
6 Select the day and use arrows to select the time and temperature for Sleep. Set the time you normally go to bed. The thermostat will automatically adjust itself to your selected temperature at that time.
Thanks
Apr 01, 2012 | Lakewood 2096ET Oil Filled Radiator Heater
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
Can i set it to a temperature that will allow it to turn on and off automatically
Any temperature you set it at, the AC unit will turn ON and OFF automatically. Once the set temperature has been reached and held for 5 minutes, the unit turns OFF, but the fan may continue to blow for a few minutes. When the room temperature rises above the set level, it will automatically turn ON again and continue to run, until the set temperature is reached and it turns OFF.
I really hope this has helped you and thanks for choosing FixYa.
Jul 21, 2011 | Whirlpool ACQ158XP Wall/Window Air...
Ac clutch kicks on and off, is there a thermal coupler?
There is a temperature control in an AC system and the compressor kicks out when the selected temperature is reached in the vehicle, it kicks on again to maintain the preset temperature.. There is also a pressure switch in the system that cuts out the compressor if the gas/lubricant in the AC is low and continued use of the compressor may damage the component.
Jul 10, 2011 | Ford Tempo Cars & Trucks
Rinnai reh15-217 burners cut out automatically after being on for about 1/2 an hour
If you're saying the burners turn OFF after 1/2 hour, but the pilot light stays lit ... I'd have to assume that the automatic thermostat control on the heater, turned the burners OFF, because the temperature you had it set on had been reached. The real question (at least for me) is are you allowing enough time for the temperature to drop and the heater to turn back ON automatically?
May 16, 2011 | Heating & Cooling
The automatic shut off quit working. Stays on all the time unless it's unplugged
Hi.
The thermostat must be replaced.
The iron uses a thermal cut off that will disconnect power to the element when the top temperature is reached.
In your case the thermostat is shorted inside, and will never cut off.
The part can be ordered calling B&D at their customer support number, listed on the owners manual.
Jan 18, 2010 | Black & Decker Professional PI8000 Iron
Leaks water inside the refrigirator part. It ices and eventually leaks to the bottom part! We keep the fridge at a normal temperature! 38degrees. please help! is there a recall to solve the problem!
The unit has an automatic defrost system that defrosts the fridge automatically when frost develops or when certain conditions are met.
  1. Defrosting starts when the compressor running time reaches 4 hours after a power outage or after the unit is turned on for the first time.
  2. Defrosting starts each time the compressor running time reaches 7 hours.
  3. Defrosting stops if the sensor temperature reaches 46.4°F(8°C) or more. If the sensor doesn’t reach 46.4°F(8°C) in
    2 hours, the defrost mode is malfunctioning.
  4. Defrosting will not function if its sensor is defective or wires are cut or short circuited.
If your unit defrosts frequently even when the conditions above are not met, you have a malfunctioning sensor. You may have to ask the help of a qualified technician to disassemble and:
  1. Check the connections of the sensor to the control board.
  2. Inspect the wires for short or cut wire.
  3. Push the reset button on the main board.
  4. Replace the sensor control assembly.
Nov 04, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Elekta Window Air Conditioner, Thermostat won't cut off.
there is a temperature sensor try to imerge it into a hot water glass and the try again.
May 24, 2009 | Heating & Cooling
Kenmore 75085 Air Conditioner Logo
59 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
