Question about Canon PowerShot A580 Digital Camera
Memory card error on A540 - Canon PowerShot A580 Digital Camera
  • kakima Jul 19, 2010
    What kind of memory card are you trying to use? The A540 is designed to work with SD and MMC cards. If your card is larger than 2GB then it's actually an SDHC card. While it will fit into the A540 it will not work.
    If you are using an SD or an MMC card, what happens when you try to format it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Having received no response in over a month, I assume this was just a matter of SD versus SDHC.
Posted on Sep 13, 2010
Why does this camera show "card error" How can I fix this?
What type and size memory card are you trying to use? The A540 works with MMC and SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards, even though they fit into the slot.
Jun 24, 2014 | Canon PowerShot A540 Digital Camera
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
Card locked error on screen card is unlocked and even new card gets same message
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Aug 17, 2011 | Canon PowerShot A540 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
A540 says "memory card error" " card locked" but 4gb card is not locked - can access card on card reader - copy on and off. a540 works with 2gb sd card no problem. please help?
The A540 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Jan 13, 2010 | Canon PowerShot A540 Digital Camera
Asking what to do?
8 GB is more than your A540 can handle. You can check with Canon, but I'm pretty sure that the max that your camera will understand is 2GB. Additionally, your 8GB card is most assuredly an SDHC card and not a standard SD card. Your A540 also does not understand SDHC format. The max card that you should buy for that model camera would be a 2GB standard SD card. These are very inexpensive these days and run about $6, shipping included:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=2gb+sd+card
Jan 20, 2009 | Canon PowerShot A540 Digital Camera
Memory card error
On the old Powershot S400, this error was caused by a dead internal "clock" button battery. Fixing it required simply replacing the battery. But before you attempt to do that, would first suggest trying a different memory card.
Jan 20, 2008 | Canon PowerShot A540 Digital Camera
Canon PowerShot A580 Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
