Question about Maytag Kitchen Ranges
I have a maytag stove when I use my burners on top and try and preheat the stove it will take about an hour to preheat to the temp set if I have the stove on and try to cook on burner the flame is low cant boil water for noodles when oven is on any suggestions
  • Anonymous Mar 16, 2014
    the clock doesnt keep time the front left burner wont light and the gas oven takes long time to preheat and makes poofing sound
I have a Maytag stove Model #MER5875QCW The problem is it
Takes for ever for the stove to reach 350c Can anything be done?
Posted on May 24, 2008
I have a maytag gas stove model mgr5720adh When I use the oven during the preheat is fine it does take longer to preheat but when it maintaining the temp I start smelling gas.
Change the igniter the igniter is not getting hot enough to open the safety valve and what it does there's not enough heat on the igniter to ignite the flame of the burner
Jan 17, 2017 | Maytag Kitchen Ranges
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
After the oven preheats the I can hear the clicking, but the oven will not relite therefore the temp just drops. If I shut off the stove and put the temp I want back in the stove will lite, but again after...
there is a problem w/the burner....kitchenaide is aware of these issues and the new burner should come with a new ignitor already attached to it,poor design...
Mar 06, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Xl44 oven burner pulses, doesnt properly heat up.
it seems the burner in the oven is clogged, by grease, carbon or corrosion, it may need replacing, specialy if this is an older unit
Jul 30, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR5745ADA Gas stove/oven. Oven takes very long to reach pre-heat temp. Think it is the temp sensor, but unsure how to locate and remove
i did a clean on my oven maytag model mgr5745ada. when i try to use the oven the preheat lite stays on for only a few seconds then i get either a f4 alarm or f1 alarm. what do i need?
Jul 14, 2009 | Maytag Ovens
Stove top element overheats
HI thanks for your question. the problem is with the burner switch. replace the switch. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Ovens
Maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
Aug 23, 2008 | Maytag CWG3100A Gas Single Oven
BURNER ON STOVE TOP NOT WORKING
some dirt or spilled food is in the orfus tbue or holes forcing it to come out under the burner!
If you ever replace the unit, get sealed burners the you can take them off and clean them!
GET HELP.
THESE GUYS CAN HELP!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 09, 2008 | Maytag Performa PAV2200
Maytag gas kitchen range/oven model# MGR575 ADW during preheat cycle in oven seems to keep trying to start left bank of burners over and over again. Gas can be heard flowing an ignition occurs and then...
that actually sounds to be pretty normal operating procedure unless im not understanding correctly, the unit will shout off, and cycle back on to maintain proper temp as cooks, the" top lef bank of burners" they show signs of clicking??? but not actually igniting correct??? and do they ever start to click when unit is completly off???
Apr 07, 2008 | Kitchen Ranges
Inacurate temperatures
Often the temp gauge is the culprit. To check temps, allow to preheat for 15 minutes. Monitor the highest temp reached after burner shuts off and record. Then monitor lowest temp before burner cycles back on again. Average out readings. Example, if high is 355 and low is 345, average temp is 350. Do this for 3 cycles and average out.
Nov 19, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Kitchen Ranges Logo
422 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
