Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
You can just hear a small click when plug or unplug it.
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezeryou can just hear a small click when plug or - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 19, 2010
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
Jun 07, 2011 | HP Pavilion dv9000z Notebook
Nothing running in refrigerator. Unplugged unit for 2 hours then pllugged back in. unit ran for about 30 seconds then stopped again
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 10, 2011 | Amana Refrigerators
My friend has a WD-65731 Mitsubishi; a week ago the image wouldn't come , so he unplugged the power cord, plugged it back and the image came. But, he wasn't able to turn it off from the remote any longer,...
try this wait until the blinking stops and then press the button. if still not working replace the lamp and lamp ballast. before changing lamp make sure you clean the dust out using a compressed air.also clean the small fan over the lamp ballast.
Sep 10, 2010 | Televison & Video
Steam wand leaks and no pressure.
Ok, remove the right side panel, you will see a red switch connected to the element by a metal coil, make sure power is off and unplugged, then press in red switch, you should hear a click, then open the steam wand and plug machine in and turn on, wait until you see small spurts of steam from wand before closing.
Jun 21, 2010 | Rancilio S24 Espresso Machine
Fridge and freezer are warm, i can hear a fan running, and i think what sounds like the condenser turning on, theres a click followed by a hum for a few seconds then it shuts off. It repeats this every 30...
at the back of your refrigerator, you will see the motor compressor below, at the side body of the compressor you'll find a small box attached to the body where the wires come in, take out the cover, before doing that, unplug it first. then take the cover out. now plug it, don't touch it.
see if you can hear any click sound then it will shut off. if yes unplug it and take out the overload relay attached to the compressor where the wires are connected. try to replace it, just remeber the wire matching.
Nov 05, 2009 | Maytag PTB1954GR Top Freezer Refrigerator
My Magic Chef Mini Fridge just stopped but the compressor is hot.
ok In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Aug 27, 2009 | Magic Chef MCBR440 Compact Refrigerator
Can not receive or send fax. When I send a fax, it says no answer, when I try to receive a fax, the other side hear it was ringing on and on, but they did not get the receiving signal.
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq22
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Tin like sound from small speakers only. No sound
switch on your speaker set in full volume unplug it from computer touch the plug , as you touch you can hear a sound ( loud hum sound) if the speaker is working. If okay then check the right jack, plug it into green color jack. you can try if your computer is okay use a headphone plug it into the jack in PC , if the computer is okay you may hear the sound.
Jul 01, 2009 | Dell OPTIPLEX 960S Desktop Computer
TV will not turn on.
hello..i think you have very big problems inside on you're TV you need a Electronics Technician to see inside the real problem.my tips is located in Power Supply Regulator..Can i know what kind TV Model???thanks
Apr 23, 2009 | Televison & Video
Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Jan 06, 2009 | Magic Chef MCBR440 Compact Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
