Question about Kitchen Ranges
How do I change the water filter on a Noritz N-069M tankless water heater?
  • james281 Jul 20, 2010
    Need specific procedures on how to replace water filter so as not to damage the system.
  • 435 Answers
The filter is located on the water inlet to the heater, it's a reuseable filter.
I've listed the steps to remove it and how to clean it.
Allow the water to cool before removing the filter to avoid scalding.
1. Close the water supply valve.
2. Open all hot water fixtures.
3. With a bucket ready, remove the inlet and outlet
drain plugs (about 0.2 gal. will drain out)
4. Take the water drain valve (with water filter) out
of the inlet.
5. Clean the water drain valve (with water filter) with
a brush under running water.
6. Replace the water drain valve (with water filter)
and close the drain plugs.
(Take care not to lose the O ring)
7. Close all hot water fixtures.
8. Open the water supply valve and check that
water does not leak from the drain plugs or water
drain valve (with water filter).
Posted on Jul 20, 2010
  • Mike Raatz
    Mike Raatz Jul 20, 2010
    There will be no damage to the system if the water is shut off, you can go the extra step of turning off the breaker. The filter is located on the water inlet (looking at the unit, lower right side) it's just below the unit facing 90 degrees from the inlet pipe. It's other function is a drain; there should be another drain plumbed into the outlet pipe (left side) once the water is drained from the unit into a bucket, just remove the filter and clean the screen as discribed on the original instructions. Once the filter is cleaned, install the filter close the drain on the outlet side turn on the water and power and check for leaks.
    Guru:
  • 632 Answers
Http://noritz.com/u/installation_manual_n_0531s_n_0631s_series.pdf
Page 26
Diagram shows exactly where filter is on the end of the water drain valve
Also save the owners manual it will provide alot of useful tips and help on maintaining the water heater.
Posted on Jul 19, 2010
  • james281 Jul 19, 2010
    I need the maintenance manual. I know where the filter is located. I want to know the correct procedure for replacing the filter and descaling the unit.
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
Error 71
EC 71 usually means you are using a battery backup that doesn't produce a pure sine wave. OR you recently had a power outage and it shorted the circuit board. if you have a battery backup try unplugging that and see if it works okay. If not, just call Noritz for a replacement c/b.
Dec 06, 2013 | Noritz 6.9 Gallon Residential Tankless...
How to change a water filter on a Noritz tankless water heater
Turn off your incoming cold water to the tankless. (you should probably do the same with your hot water out line just in case). find the black cap that screws sideways into the cold water connection on the bottom of the unit. unscrew the black cap. the filter is supposed to be attached but it almost always comes off. grab a screw driver and stick it in the hole that the black cap was covering. angle it and drag the filter out. you may end up putting a hole in the filter this way but it doesn't matter if you are replacing the filter anyways. once you pull it out make sure you have a little rubber washer on the new filter or else transfer from the old one. the new filter should actually attach itself nicely onto the black cap so once you've removed the old one all you have to do is screw the black cap/filter combo piece back onto the cold water connection and you're done.
I suppose I should mention you will want to have a bucket under the pipes and everything because your unit will empty all the water that was in the unit out of that hole.
Apr 13, 2013 | Noritz 6.9 Gallon Residential Tankless...
I have a Model N-069M and i get a flashing code 16. I just had the unit flushed two days ago and i still get the same code. thanks for any help
I feel your pain. I am experiencing the same issue which started about 3 weeks ago. First it happened twice that first week and we discounted it. Now that my heater has been flushed the same issue is occuring. I called Noritz 3-4 times now and they are saying that I may have high manollowifold pressure and should have that checked.
FollowUp: Plumber determined my Natural Gas inlet line was too small. He Tee'd off before my manifold to other appliances and fed with a 3/4 line. Issue resolved and it has been trouble free since. (Updated 2/2017)
Feb 12, 2011 | Noritz 6.9 Gallon Residential Tankless...
What does F-76 code mean on a Noritz M-069 panel
F76 is a communication error. It usually occurs if you connect or disconnect a quick connect cable or remote control when the tankless heater is connected to electricity. (If you have a quick connect system, make sure you only have 1 remote and 1 quick connect cable.) To get rid of the code, try disconnecting electricity for 20 seconds, reconnecting electricity, and turning the remote on. If the code returns, you may need to replace your quick connect cable, remote cable, or even remote control
Sep 14, 2010 | Noritz 6.9 Gallon Residential Tankless...
Noritz f 76 error blinking f 76 and on off light blinking at the same time. Everything works fine turned on and off hot h20 it goes to burner on 120 and then goes back to blinking f 76 after burner...
F76 is a communication error between two quick connected heaters. To clear the code, disconnect power from both heaters, wait 20 seconds, then reconnect power.
Apr 23, 2010 | Noritz 6.9 Gallon Residential Tankless...
Noritz Tankless gas water heater making load roar when the Hot water is turn on
Sounds like gas pressure is too high..not set properly or exchanger is clogged. Best to get technician out there for this one. Could be dangerous
Apr 08, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
I have a Noritz Tankless outside my home on wall for several years. Works fantastic until now. Controller is going blank intermittently. Able to restart after resetting GFCI, plugging and replugging. On...
It sounds like your GFI is tripping. There are two common reasons for this to happen 1) plugged into another GFI 2) moisture on the gfi. I'd look for evidence of a water leak which is tripping your gfi. Look for puddles, water spotting, water hardness, etc.
Jan 28, 2010 | Noritz 6.9 Gallon Residential Tankless...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Kitchen Ranges Logo
125 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
