Question about Brother LS-1520 Mechanical Sewing Machine
My brother LS-1520 sewing machine is having major tension problem
My brother LS-1520 sewing machine is having problems with the thread underneath. The tension seems to fluctuate but no matter what I change the tension dial to, the thread seems to be so loose underneath that it pulls out.
We tried oiling the bobbin areas, but that didn't help with the tension problems. I have sewn many kinds of fabrics on this machine, but recently, I can't get the thread underneath to stay put. Sometimes, it even just pulls completely out.
Please help.
    Genius:
  • 1,788 Answers
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Posted on Jul 27, 2010
Brother LS 1520 I was in zig zag mode and broke a needle. Now that I have replaced the needle, the needle thread will not pick up bobbin thread.
Are you sure that you replaced your needle right? The flat side must face the rear of the machine and did you put your needle on a straight stitch? I hope it didn't mess up your timing. But try this and I have my fingers crossed for you that it is something simple.
Dec 11, 2010 | Brother LS-1520 Mechanical Sewing Machine
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
How to thread bicor vx 1005 sewing machine?
Most older machines start the thread from the spool on a spool holder then the thread goes through a tension dial, on to another tension holder inside the case. Then make sure the thread is going through a lever that goes up and down with the needle, through a thread holder near the needle.
Jul 14, 2009 | Brother LS-1520 Mechanical Sewing Machine
I HAVE A BROTHER LS-2125 SEWING MACHINE AND THE STITCHING UNDERNEATH IS OK BUT THE UPPER THREAD IS LOOSE AND ALSO SKIPS
Sounds like either the bobbin case tension is too light or is not in the tension at all.
Consult your manual for how to place the thread in the tension and retry. Increase the bobbin case tension if necessary.
The top tension may be set too high.
Jul 11, 2009 | Brother LS-2125 Mechanical Sewing Machine
Needle & bobbin are out of sinc
could be your tension try it set at number 4
Mar 27, 2009 | Brother LS-1520 Mechanical Sewing Machine
Brother won't sew
My Brother machine is sensitive. You may have already done this, but...
Rethread the top, following diagrams and instructions precisely.
I have taken the front off the machine to find a nest of thread in the upper part of the machine.
Remove the bobbin and bobbin case, and reseat both.
Check the needle. If it is bent even slightly or not seated well, the whole needle shaft can lock up.
FAQs Troubleshooting LS 1520 Others Brother
Aug 11, 2017 | Brother LS-1520 Mechanical Sewing Machine
Having trouble with my bobbin thread
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine. Good Luck!
Aug 28, 2008 | Brother LS-1520 Mechanical Sewing Machine
Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Brother LS-1520 Mechanical Sewing Machine Logo
510 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
