Question about Sigma Sport BC506 Bike Computer
The speed mph varies widely even when the bike is going at a consistent pac. The computer will read 3 mph and then jump to 20 mph which the bike is just rolling without a big variation in speed.
  • 29 Answers
Another cause could be that there is too much clearance between the sensor and magnet. Move the sensor up or down the fork and adjust the magnet to get a closer gap.
Posted on Mar 29, 2013
  • 1,514 Answers
The most likely cause is that the front wheel is a little loose. This causes the magnet on the spokes to pass the receiver on the bike frame at different distances. If it passes at more than 1 mm it won't be read so it is probably only reading some of the rotations of the wheel. The solution is to loosen the wheel and tighten the nuts inside the forks a little. When it's at the right tightness the weight of the wheel valve should be just able to turn the wheel until it reaches the bottom with the wheel raised off the ground. There should be very little or no sideways movement in the wheel. Also ensure that the magnet is not moving.
Posted on Jul 19, 2010
I have a hawk 250cc Chinese dirt bike with 80mph on the speedometer but I only can get it to 50mph what could I do to get it to 80mph
Speedometers always go a lot higher than the maximum speed of the bike. In the case of your Hawk 250 the quoted top speed is 74.5 mph. In my experience of riding trail bikes and competitive enduro, you will only reach it under ideal conditions. That is usually a following wind, downhill, with a light rider, riding one handed with your head on the tank. NOTE - This isn't a very safe way to ride! The main problem with dirt bikes is the riding position which is sitting high up like a flag in the wind which causes extreme wind resistance which will easily know 20 mph off your top speed.
your bike also needs to be correctly set up, and I doubt that Chinese engineering workmanship is that good. at 80 mph things can go bad very quickly.
RPS 250cc Hawk Dirt Bike
Mar 09, 2016 | Motorcycles
Speedmoter jumps to 20 when i put truck into reverse or drive
SOUNDS LIKE A BAD SPEEDOMETER if you can use an OBDII while driving and look for DTC output from speed sensor. possible loose connection can cause this as well
Nov 06, 2012 | Ford Cars & Trucks
Dodge charger wont go over 35 mph
I have a 2007 Dodge Charger won't go over 35-40 mph and once you get up to that speed it jumps back and forth and when you start it and put it in gear to go it jumps real hard. My mechanic and a transmission specialist said it was a bad tranny I bought a used tranny and the used one wouldn't even shift into gear so now putting another tranny and another computer system in it. Does anyone know anything else it could be I'm so tired of this vehicle
Apr 23, 2012 | 2007 Dodge Charger SRT8 Sedan
Lost power when trying to pull out of a gas station, turned off ignition and after about a minute was able to get power to bike but clock was flashing as if it lost all power. Later that day while riding...
Hi Nsmith845, and the usual suspects are:
1. Severely discharged or damaged battery.
2. Loose, corroded or broken battery cable.
3. Alternator not charging or below normal rates.
4. Failed ignition coil, ignition/electronic module.
5. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor.
6. Faulty ignition switch.
7. Water or dirt in fuel system, carburetor or filter.
8. Fuel tank vent system plugged or gas cap not venting.
9. Fuel tank empty.
10. Fuel valve vacuum line broken or carburator vent line closed off.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump, pressure regulator and or fuel injectors.
For a prime suspect please visit website below and good luck:
Harley Diagnostic Codes 04 to Present
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 06, 2011 | 2011 Harley Davidson FXDWG Dyna Wide Glide
How to change from mph to kph
As the triumph is a British bike, the speedo reads in MPH. You can get stickers off the internet (ebay) that you can stick on the speedo glass to remind you of the KPH speeds.
Also be aware that my Triumph speedo from around 12 years ago read faster than I was actually doing any way, even at speeds of only 50kph!
Jul 11, 2011 | Triumph Street triple Motorcycles
I am running a 2006 fxdwgi with v & hines big radius and a k&n filter, had a scremin eagle fuel pack fitted by dealers, std harley plugs and braided after market leads. after fitting the fuel pack...
It sounds like your bike's fuel-air mixture is too lean. Lean fuel-air mixtures causes the engine to spit back through the intake and surge at the speeds you're talking about. You cannot maintain a steady speed at about 40 mph. I'm sorry but I know nothing about fuel injection systems. I suggest that you take your bike to a shop that has a dynometer and an exhaust gas analyzer. They can run your engine up through the complete rpm range and check the fuel-air mixture throughout the range. They should be able to make the changes necessary to get your bike running correctly.
Good Luck
Steve
May 30, 2011 | 2006 Harley Davidson FXDWGI Dyna Wide...
Hello, I recently purchased a 1973 Suzuki TS 185. The bike turns over and starts right up very easily. When the bike idles I can rev it and it seems to work very well in first and second gear. However,...
Check for air leaks. You probably need new crank seals and a new intake manifold. Check your reed valves if you have them and do not hold the throttle wide open if it is bogging you will score the cylinder by running it lean.
Oct 06, 2010 | Suzuki TS 185 Motorcycles
Odometer reads 0 all the time even upononeat 85 still reads zero?
one end attaches to speedo head and bottom end to front of trans. Should have a tag end showing
Mar 07, 2010 | 2002 Suzuki GSX-R 600
Speedomoter works rarely, no mileage recorded, needle at 20 MPH
the sensor on the gearbox needs replaced common problem with that age group. sensers are around 20-30 quid hope this helps?
Aug 24, 2009 | 1999 Isuzu Rodeo
2003 Camry Speedometer reads 150 mph constantly.
i would disconnect the battery again let it sit for 15 minutes, i changed an alternator and jumped the car then started driving and that happened to me, 20 minutes of driving and the computer finally kicked in and started working again. good luck
Aug 17, 2008 | 2003 Toyota Camry
Sigma Sport BC506 Bike Computer Logo
207 people viewed this question
Top Sigma Sport Cycling Experts
kirkjw
Level 1 Expert
Tom Chichester
Are you a Sigma Sport Cycling Expert? Answer questions, earn points and help others
