Question about Western Digital Caviar WD800BB 80 GB Hard Drive
I moved my desktop hard drive WD 8000BB to an external usb enclosure. I have everything connected according to the manual but can't see it in my computer as an external storage device. Any idea of what I'm doing wrong?
  • 702 Answers
Does it power up when you plug it? If not, it could be a problem with the power from the USB port. If it does, see if it shows up in the Disk Management.
More ideas: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Posted on Jul 19, 2010
My WD external hard drive will no longer work with my MacBook computer. When i plug it in it says that it cannot read the external hard drive. The computer says that i should restart the external hard...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 14, 2010 | Western Digital Passport WDXML800UE...
Windows vista cannot detect my wd 320gb element external harddisk
* the USB cable
* the power-adapter
Dec 11, 2010 | Western Digital Elements powered by WD 320...
When i plug in my WD External Hard Drive 500gb it show to be un readable in disk managen ment and gives no options to fix it
* the USB cable
* the power-adapter
Dec 09, 2010 | Western Digital 500GB My Book Pro-External...
The light for my external hard drive turns blue but nothing appears on my desktop, is there something wrong with my external hard drive or the usb cable?
* the USB cable
* the power-adapter
Nov 18, 2010 | Western Digital External USB 2.0 80 GB...
I have a simpletech harddirve 120 GB. Had it for about 2 years. The blue and red light usually appears and you could feel it run. Now theres no sound or moving parts and now only the red light appears. ...
* the USB cable
* the power-adapter
Nov 10, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer wont read portable hard drive
* the USB cable
* the power-adapter
Nov 09, 2010 | Western Digital WD Passport 250GB Portable...
Well my external hard drive( hde6-640g) no longer registers on my computer i get the message"windows does not recognise this usb device" can u help , it is a wd hard drve inside the case.
* the USB cable
* the power-adapter
Nov 08, 2010 | Western Digital Computers & Internet
I have a 1tbexternal hdd drive and it stopped working. i tryed to switch the plug and put it on other computer but nothing.....
The Passport has four major components:
* the USB cable
* the power-adapter
Get the part-number and serial-number from the label on your disk-drive, and access the W.D. web-site, and use "check warranty status", to see if W.D. will replace the Passport, at minimal cost to you.
Nov 07, 2010 | Western Digital Passport 160GB External...
External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
How do I Recover data from an old hard drive
This may sound silly, but does the external enclosure have power? You may have neglected to connect the required power adapter, or it may not be working properly. You might also have a problem with the enclosure's internal power or data cables. They are sometimes pretty flimsy, and sometimes they can go bad.
There's also the chance the drive itself is bad and isn't being detected as a result. Or the interface board in the external enclosure may have failed, and the drive is OK but the computer doesn't see it. If you are connecting to a desktop PC, you can try connecting the drive directly to the main board using an IDE cable and try accessing it that way. Just be sure to set the master/slave jumper accordingly if you do that.
Feb 07, 2009 | Western Digital USB 2.0 External Enclosure...
Western Digital Caviar WD800BB 80 GB Hard Drive Logo
126 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
