Question about Car Audio & Video
Circuit for Watson Car Radio model no. CRC8448MU
No radio reception, everything else working well.
5 Suggested Answers
  • 151 Answers
SOURCE: radio has no reception
Stupid question , but check if antenna has come loose if not then you have internal problems
Posted on Apr 21, 2009
SOURCE: bad radio reception
Problem: Radio Reception is bad to non-existant. AM is usually worse than FM.
Reason: Antenna connector has come loose, and needs to be reconnected. This happens when a passenger pushes the carpet toward the firewall and disconnects the plug.
Affected Model Years: 1997, 1998, 1999, 2000, 2001, 2002, 2003
Permanent Fix:
1. First check to make sure the antenna at the back of the radio has not come loose.
2. Remove the plastic cover on the front passenger door threshold held in place by three pressure clips.
3. Peel back the carpet on the front seat passenger floor.
4. Locate the coax antenna cable running along the side.
5. Reconnect the two pieces of antenna that have come loose.
6. Roll the carpet back, and re-install the threshold cover.
Posted on Jun 30, 2009
  • 8 Answers
SOURCE: I have replaced the car radio antenna on 1993
Check your connections on the antenna again. Am usually gets decent reception. sounds like your antenna connection isnt fully connected either at the stereo connection or at the actual antenna connection.
Posted on Mar 29, 2010
SOURCE: No AM reception for car radio...do get FM reception.
I was having the same problem with a jvc kd hdr 30. I Installed it myself over a year ago and never wanted to deal with the issue. Finally, I decided to take a look at it today.
On my head unit, all wires were connected except one blue one with a tag that says "do not connect to power, for remote device or power antenna only." This unit is in a '97' MBZ E320 with no visible antenna; I think it is part of the windshield. In any case, between the wiring diagram in the manual and the harness that is part of my car, I was left with 2 blue wires to choose from, one with a white stripe and one with a gray stripe. After testing both for power or ground, I determined neither had power with key on or off. Both had high resistance ground when compared to the chassis ground. In other words, I measured between chassis and these wires. First, I took a wire and connected it to the chassis ground and connected the other end to the blue wire coming from the unit while tuned to a local am station. This simply killed all reception am or fm but did not harm the unit. Next, I connected the blue wire with gray stripe of the car harness to the blue wire of the unit and again this killed all reception. Then I connected the blue wire with white stripe of car harness to the blue wire of unit and presto magic I had great am reception.
I am guessing that this blue wire with white stripe must be part of the antenna itself or perhaps is a connection that increases antenna power. Maybe 'power antenna' on tag refers to an actual powered antenna (like as in amplified?) and not as in an antenna that rises up out of fender, as I believed.
This may not help the first person with the question, but maybe it will help someone out there who searches for these kinds of answers like I do from time to time.
Posted on Nov 21, 2010
Toyota corolla professional aerial problem, reception on radio
Some tints have metal in them so it might cause you grief but how is the radio when you wind down the windows ?
A power aerial might fix the problem put in the front fender and then run to the radio via a coaxial cable.
However in my car it was the radio that was the cause of the same bad reception and it worked on one channel only.
I have since replaced the radio but this may not be the cause of your problem and you would want to really know if the radio was the cause before incurring an expense of a new car radio.
May 28, 2017 | Cars & Trucks
Am-fm doesn't work on radio 2001 tahoe, everything else works, what could be the problem
Antenna connection is the place I'd start with. Something is wrong with the cable or the connector.
Aug 23, 2012 | ACDelco 2001-2006 AC DELCO-FW311 Chevy...
Why have I no radio reception on peugeot 307?
go step by step to find the fault.
check antenna connection behind the radio
check roof aerial and wire connection underneath it.
Take an old radio's antenna and connect it to your car's radio antenna input and check whether your car radio is working properly.
Apr 15, 2012 | Peugeot 307 Cars & Trucks
There is no AM radio reception in our Endeavor, everything else works fine. Any suggestions?
This is caused in may cases by a defective antenna ground to the chassis of the car or a defective antenna lead to the radio..
Sep 23, 2011 | Mitsubishi Endeavor Cars & Trucks
Poor quality reception on radio of my Porsche Boxster S which I just picked up at the weekend. Year 200 model. The CD player works fantastic and the sound quality from the speaker system is excellent...
It might be a dud radio but if you are lucky it could be the aerial or aerial preamp if one is fitted. Removing the radio so a known good test aerial can be plugged in is the best first step.
Feb 14, 2018 | Car Audio & Video
I have replaced the car radio antenna on 1993 Discovery. Works fine on am very pore reception on fm. The car radio, factory fitted, is Eurovox Model 92039986. Is there an adjustment to tune the radio to...
Mar 29, 2010 | Car Audio & Video
Radio does not work
put a wire in the antenna hole while radio is on if you get some reception then you know its your antenna do you have sirius if you do it sometimes it runs through your antenna if you dont then check your antenna wire where it connects to the antenna good luck.....
Dec 28, 2008 | Pyramid PDVD79 CD Player
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Car Audio & Video Logo
822 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
