TV shuts off. Red light blinks in pattern. - Televison & Video
  • Anonymous Dec 06, 2008
    model number KP-51WS520
  • sbetts30 Feb 03, 2009
    tv shuts off and won't come back on for a long time. try turning it off at the stand by and then turning it back on again, but it immediately shuts back off.
Model KDP-51WS55O and it blinks 10 times
Posted on Oct 12, 2008
  • 8,617 Answers
Need to know your model number and also how many times it blinks
Posted on Apr 21, 2008
4 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic Pt-53TW53G projection tv
5 Blinks means IC4511 thats located on the DG board which is the small board on the left side in front of the signal board looking in from the rear of the set.
Posted on Oct 31, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 50HX81 projection 'tv- blinking red light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
My Mitsubishi WD 65736 TV has a bad Fan ... according to a tech that came out . How do I tell which of the 3 fans is bad .. all 3 come on for about 15 seconds then shut down all at once ... start up again...
Hello, count the blinking light pattern. It may blink 2 to 9 times, pause and repeat the pattern again. Does it ever light the screen when it's cycling on and off? Let me know....tks
Feb 24, 2015 | Mitsubishi WD Televison & Video
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My tv shut off by itself & the standby lights flashes 4x in red
The four blink pattern indicates inverter failure. Since there are different inverter boards for this model (depending on the serial number), I recommend that you take your TV to an authorized Sony servicer for repair.
Sep 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony shuts off after being turned on, stand by/timer light blinks
The blinking should be in a pattern of a count, pause, count. That is an indication of the problem circuit. Can you post that count please? That info will allow me to give you possible defective parts and costs for the repair.
Thanks,
Dan
Feb 18, 2009 | Sony KV-27V42 27" TV
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Monitor shutting off with blinking standby light.
Very expensive to fix.You hve a bad ysus board.Nec will re-build theboards as a set 1000.00 plus
Dec 14, 2006 | NEC PlasmaSync 50MP1 50 in. Television
Televison & Video Logo
224 people viewed this question
Top Televison & Video Experts
Electro Med Services...
