Question about Quinny ZAPP Stroller
Worn out seats - Quinny ZAPP Stroller
    Champion:
  • Quinny Expert
  • 223 Answers
You can buy replacement seats cheaply on ebay. new & used
Posted on Aug 07, 2010
Fixing vibration at hwy speeds,its not the balance. starts at b50 and gets worse,feel it in steering wheel and seat
Check for worn tie rod ends, worn rubber parts on all suspension parts. Recheck tire balance too. I had to go back to my tire shop to get them re-balanced twice before they got it right.
Jul 28, 2017 | Seat Cars & Trucks
What brands/models of front drivers seat can be used to replace worn factory seats?
go to a speed accessories shop as there are a number of racing seats that will replace OEM seats
go e-bay and type in ---seats for ( your make and model of car)
get motor magazines and there are seats advertised in those pages to help you find a shop that sells seats
Dec 15, 2015 | 1996 Toyota Celica
2001 Seat Leon S, 1595CC Petrol, 5DR, Manual, engine sounds like diesel engine. what possible problems?
change your oil now and once you take off the oil filter look for metal shavings if there are take it to a trusted mechanic asap
Dec 17, 2014 | Seat Cars & Trucks
What would cause gas to leak from carburetor on pressure washer
Needle and seat problem probably with the needle worn or seat worn or both OR needle sticking OR float and/or float level adjustment problems.
Sep 19, 2014 | Garden
Why does my kohler quiet seat not soft close anymore
The cams are worn out inside of seat or it may be to lose you have to tighten up the seat if there is any adjustments if not it is worn out replace toilet seat.
Jul 01, 2014 | Kohler K-4748-47 Almond Saile Quiet Close...
Car seat
Working for the dealer- doesn't tell you a thing
The switches you use could be worn,the mechanics
of the seat & motors could be worn or binding.
You could have seat module issues
The dealer, while too expensive to be at
in the first place, should have put some time into it
once your there
You could try a repair shop near by
Jul 26, 2013 | Hyundai Cars & Trucks
What causes a valve to burn
The cause of valve to burned are worn valve seat,worn valves,overheated engine, Its mainly the exhaust valves that burn due to worn valve seats
Mar 23, 2012 | 1990 Toyota 4Runner
Base of seat, has foam worn away inside, so as you can feel the metal. area where you swing right leg out, on the bit where the outer edge of seat base sticks up, as in sports seats.
Best thing to do is go to the Auto Salvage and look for the same seat for you car. The years are interchangeable so you don't have to pick out a seat from a 8 year old car but from a car newer. As long as the seat is the same, it should fit and less work for you. Good luck and just take your time on searching for that perfect seat to replace your old one, or you can take it to a Automotive upholstery place and they can replace the worn out seat cushion.
Oct 24, 2009 | 2001 Volkswagen new Passat
Z3 seat rock repair
There is a ratchet system on the slide rail below the seat, sometimes the teeth on the ratchet wear out, especially when adjusted often. The hook holder that actually clamps onto those teeth, may be broken off or worn out aswell, and either of these will need replacement. Some models also come with air-suspension and a locking device, the spring on this device may be missing or worn, this will also mean a new one is neccesary for repair.
BUT... If you don't want to fork out, and are going to leave the seat in one position for a long time, may I suggest simply welding the rail to the seat, this is a permanent thing and would require you to throw away the entire sliding system, if you ever need to adjust the seat. Hope this helps you. Good luck!
Mar 12, 2009 | 1997 BMW Z3 Roadster
2nd Row Seat will not attach to floor
EITHER THE SPRING HAS GONE OR THE LITTLE V GROOVE IS TOO BADLY WORN, EASIEST THING IS TO REMOVE SEAT, TURN UPSIDE DOWN TO REVEAL THE PROB, IF IS THE V WORN, SIMPLY FILE THE PROFILE BIGGER
Feb 26, 2009 | 2003 Ford Explorer
Quinny ZAPP Stroller Logo
41 people viewed this question
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Oloyede Monsuru
ray gallant
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
