Question about RCA HD52W59 HDTV Projection Television
Lines across the screen..
After 5 years I now have snow.. lines across the screen, sometimes worse than other times, depending on what we are watching, i.e. backround colors on the screen ..
  • 84 Answers
Open the front panel, about where the sound is, and look for 3-6 knobs, adjust those until you receive a good picture.
Posted on Jul 19, 2010
Limes across screen when first turned on, by turning off and on sometimes fixes it, what could cause that problem?
If the lines are colored or even look 3d it is a convergence problem--if other lines it will depend on what they look like and what the model number is.
May 27, 2012 | Mitsubishi Televison & Video
Our three year ol Samsung TV has dark horizontal lines across the top of bottom of the screen. It is getting worse
Welcome to fixYa!
When you see lines like these across your LCD, it indicates a problem with your monitor's electrolytic capacitors.A faulty filter capacitor in the power supply board (SMPS board) can cause horizontal lines across your monitor screen.Horizontal screen lines are one of the most visible problems I see in LCD monitors & TV's that are 3-7 years old. It can happen as much from heat, humidity & less-than-ideal operating conditions, as it can from fluctuating current supply or manufacturing defects.
The way to repair horizontal screen lines is by removing the capacitors from the printed circuit board (PCB) and testing them with a LCR meter.
If it shows zero, there's your confirmation that the specific capacitor needs to be replaced.
now if you can replace them your welcome but i wont suggest that , cause you may break it more....!
any ways do comment if it helped you in any manner!
Apr 30, 2011 | Samsung HL-R6168W 61" HDTV
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
HD Problems
ya buy new hd antenna non powered sound like antennna messing up
Jan 06, 2008 | Televison & Video
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
BLACK Lines and having to reset.
i assume that the 'black lines' are 5 bars of dark video spaced equally across the screen. this is a symptom of dirty heads. use a mini DV cleaning tape, and the problem should go away.
Jun 09, 2007 | Panasonic NV-GS15 Mini DV Digital...
Lines across screen
The screen you have is almost certainly on the way out. This type of fault is in the Horizontal Flyback section of the Monitor. Usually components fault or age and change value, these lines are normally "Turned Off" so ya can't see them, that "Turn Off" circuitry is going faulty.. it will only get worse. I suggest a new, or 2nd hand monitor as they are so cheap these days fixing CRT monitors can be cost prohibitive.
May 10, 2007 | Gateway FPD 1510 15.1" Flat Panel LCD...
RCA HD52W59 HDTV Projection Television Logo
79 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
