Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Smoke bellows from exhaust and stalls,the smoke is white and comes and goes,but the tractors blade will stall the motor when engaged.
  • Mike Squire Jul 19, 2010
    Your description sounds like the coil to the ignition is not getting enough power, does the mower do this even with a fully charged battery and if so have you cleaned all the battery and other accessible connections?
  • 284 Answers
Sounds like a blown head gasket replace it
Posted on May 28, 2014
    Sergeant:
  • 200 Answers
Sounds like the piston rings are worn out.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Blows white smoke dies
Blowing a light colored smoke can be an indicator of burning oil. Have you checked your oil level? If it ran low it may be ceasing from heat and stalling. If it was running rich with too much fuel it should be dark colored smoke which can cause stalls. If your unit has a radiator a bad head gasket may let radiator fluid into the combustion resulting in white smoke. A little white smoke on start up can also just be moisture burning off in the exhaust but this should not cause stalling conditions, however if you're low on fuel that could contribute too. More details are important to narrow down your problem.
May 29, 2013 | Craftsman Garden
Lt200
Sounds like you may have some internal engine issues. Check your spark plug(s) to see if they are oil soaked. If so, you may have some issues with the engine.
Jul 22, 2017 | Craftsman Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Riding mower stalls when PTO is engaged.
check the kill switch and the wire it could be that a small piece of the covering came off and is grounding to the deck or frame there by killing the engine the jerkink of the mower maybe whats causing the wire to come into contact with metal..good luck
Apr 03, 2010 | Garden
Mower wants to stall when blades are engaged on a Huskee 13hp 38'' cut Tecumseh engine 6 speed on the go shift
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Jun 23, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Engine stalls, check engine light, not fuel filter.
the white smoke as it stalls could be steam in the exhaust. This is caused by coolant leaking into cylinders from a leaking head gasket. You should check cylinder compression next with a compression tester.
Jan 10, 2009 | 1991 Honda Civic
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
322 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
