Question about Marantz SR-5600 Receiver
I have a Marantz SR-5600 surround Receiver. It has been shutting off the volume at various intervals recently. When I attempt to turn it back on a display reads " Check POW5
    New Friend:
The POW5 fault indication means that the 5Volt power supply grid is not OK. The unit needs to be repaired by a professional repair engineer. No user servicable parts inside.
Posted on Apr 28, 2015
5 Suggested Answers
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
SOURCE: what is the error POW 5 on a marantz sr 7500
I have a POW 5 failure on a marantz sr 7500. Anybody know how to fix?
Posted on Aug 01, 2010
SOURCE: When I turn on the receiver it displays check
I have the problem of check POW5 too and have the similar procedure taken several times but it doesn't help. What actually problem I have encountered? Or the quality of this brand is not reliable? Does any body help?
Posted on Apr 28, 2011
dunnbiker
  • 8546 Answers
SOURCE: I own a Marantz SR
Hook, yes. Use with NON-Bose 901 speakers, NO.
The 901's need a dedicated amplifier. Get one, then use the L/R Pre-Outs to feed it.
Posted on Jul 31, 2011
Testimonial: "Thank you very much. I have not unpacked the speakers yet. I'll take them back. Any suggestions for a quality pair of speakers for under $1200.00?"
Marantz SR-66 Shut down!
Sounds like the protection circuit is tripping. With power off, check for loose speaker connections. Also, look very closely for shorts in the speaker wires. Even a single loose strand can touch another connection and create a short, which shuts down the receiver.
I would take take the frequency splitter out of the circuit and see what happens. Check for acceptable impedances in the manual. The receiver may not like the load the splitter presents.
The receiver may have settings for bi-amping. Then you use one set of terminals on the back for treble, and a different set for bass.
Feb 03, 2015 | Marantz SR-66
Humming/Buzzing noise in my Marantz SR5600-even on lowest volume-
Check the main filter capacitor at its power supply section circuit. Electro help
Nov 19, 2014 | Marantz SR-5600 Receiver
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Marantz problems
my sound on my marantz av surround receiver sr5003 stopped working, i need help to restore it:
Jan 01, 2014 | Televison & Video
Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Dec 29, 2008 | Marantz SR-19 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Feb 05, 2008 | Marantz SR-5200 Receiver
Marantz SR 7200 Receiver
DSP (Digital Signal Processing) Board is probably defective or has Poor solder Connection on one of the Ic's on that board. Board cannot be Obtained from Marantz. Must be troubleshot at component Level and requires a very knowledgable tech to repair it. I have done a few of these in the past and usually charge $50 to Evaluate and Give estimate. kstahl65@att.net
Dec 26, 2007 | Marantz SR-7200 Receiver
Power shuts off after 2 or 3 sec.
please remove all speaker from receiver-volume down and test if the receiver shut down it needs to fix in service center-if not insert speaker one by one until you find the bad one-change its cable first and then change speaker itself.
Nov 29, 2007 | Marantz SR-5200 Receiver
Marantz SR-5600 Receiver Logo
474 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
