Refrigerators Logo
Posted on Jul 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water freezes underneath the pull out freezer floor, but it also drips into the refrigerator and leaves lots of water standing underneath the vegetable and fruit bins and on the shelves. It is a pain to be continually mopping up so much water. Can you tell me if it can be fixed or what to look for?
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Jul 19, 2010
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10843969
Points
101584
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerWater freezes underneath the pull out freezer - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Water is dripping from freezer into refrigerator
heatman101
3helpful
2answers
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
2helpful
WATER FREEZES ON THE BOTTOM OF THE FREEZER
I have an LG armoire style fridge/freezer and it had lots ice in the bottom and would eventually drip onto the floor. The problem was with the defrost controller. The moisture that enters the freezer when it is opened condenses and freezes on the freezer coil/fins. There is a heating element that sits under this coil which gets turned on by the defrost controller to melt the frost/ice. As the frost/ice melts it drips into a metal tray which channels the water to a drain hole to have it drop into the drip tray underneath the unit for it to evaporate. The problem is that the before the water has time to leave the freezer, it freezes thereby plugging up the drain hole and thus causing subsequent defrost cycles to have the water flow into the bottom of the freezer where it freezes. Eventually the bottom of the freezer fills up with enough ice for the melted water to flow onto the floor. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
5helpful
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
WATER DRIPPING INTO REFRIGERATOR AND FREEZING
Chances are, your doorseals are shot. This will allow excessive moisture into the unit.
3helpful
Water keeps dripping under the fridge.
In a frost-free refrigerator/freezer the frost that would normally accumulate on the inside wall of the freezer is removed by heaters imbedded in the freezer's walls. Periodically these heaters are turn on to melt the frost which then exits the freezer as liquid water through a drain in bottom. This water accumulated in a pan underneath the refrigerator and is supposed to be removed by evaporation. If the flow of melted frost from the freezer is greater than the evaporation rate in the pan then the pan will overflow and you will get a pool of water on your floor. A bad seal on the freezer door will allow more frost to form inside. Also if you leave the freezer door open a lot you will accumulate more frost. The evaporation rate in the pan can be affected by the ventilation around it. If the vents on the bottom of your refrigerator are clogged with dust it will decrease the evaporate rate in the pan. In addition, many refrigerators have a fan the pulls air around the pan. If this fan has stopped working the evaporation rate in the pan will also decrease.
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 • Freezers
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
