Question about AT&T Siemens S46 GSM Cellular Phone
What function does Siemens logo! GED1 052 2FB00 OBA5 perform in a dual fuel gas/oil burner if Honeywell flame control is monitoring combustion?
Rg3 oil boiler won't fire Has power and oil Stats are up and programmer set to run Reset button pressed 4 times over 4 days no response or noises What next ?
I guess maybe the programmer/timer or other circuitry is defective and preventing power being supplied to the spark generator and/or fuel pump/combustion fan or perhaps the flame monitoring circuitry isn't working.
When a light oil burner starts the ignition spark is switched on first followed by the combustion fan and then the fuel pump supplies fuel to the spray nozzle under pressure and produces a jet of fine mist which ignites. If the flame dies the flame monitor signal also dies and the safety circuitry shuts off the pump.
That is roughly how many light oil burners work and as you now know there is a lot that should be happening, that is unlikely to happen if everything isn't in good order due to the requirement for safety.
Some Rg3 information is available to download if you are interested but if you want your boiler working quickly I advise you contact a professional.
Jan 04, 2018 | Heating & Cooling
I have a Armstrong SX80 gas furnace, T-stat calls for heat, combustion fan starts, in 1 1/2 min burner lights,this month t-stat calls for heat, combustion fan starts no burner ignition,
Check pressure switch and hoses to it . check air filter is clean . check you have gas in the line . check connections on gas valve check flame sensor
Dec 05, 2017 | Heating & Cooling
I am working on a monitor 2400. heater will run normal until it reaches set temp. when it goes to mid burn the flame goes out and code 14.
E14 Flame failure: There are obstacles at circulation air inlet or outlet. Fan cage is clogged with dust. Gas pressure dropped when other gas appliances are turned on. (this may also apply to K1 fueled units if you have another K1 based heater)
Here are the rest of the fault codes I found:
Digital Display Reason of indication Trouble Point
E01 At pre-purge, flame rod is sensing flame when there should be none. Flame sensing circuit, grounded flame rod or pinched wire. E05 After power on, power supply to the microprocessor timing circuit is incorrect. Timer clock circuit bad or power cycles (hertz) to unit above or below acceptable levels.
E06 A starting of operation, the circuit to drive photo triac of solenoid pump is malfunctioning. Solenoid pump control circuit has a malfunction.
E08 Revolutions per minute of combustion blower are malfunctioning. Combustion blower or combustion blower control circuit has a malfunction.
E13 No ignition. Failure of ignitor, solenoid pump or circuit board. Incorrect wiring or flame rod touches to burner parts. Air pressure switch or overheat open.
E15 Power supply voltage too low. Voltage too low or power detector circuit has a malfunction.
E16 Load failure of combustion blower motor Flue pipe is restricting air flow.
http://www.keepuswarm.com/upload/M2400OwnersManual.pdf
http://shdashan.com/english/user%20manual%202200.pdf
Oct 29, 2015 | Heating & Cooling
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
My LRG 30357ST gas range burners flame are too low, How can I increase them?
Do they go out on low setting? If so then your regulator is faulty, Never adjust flame higher unless reg. checks out fine. Even then get a qualified tech to do that
Feb 04, 2013 | LG LRG30357ST (Dual Fuel) Stainless Steel...
My older hayward h250 is not igniting now
It would appear you have a Hayward H series dual-thermostat pool heater. These systems were designed for use with two temperature thermostats so that the heater could be used as both a spa heater and a pool heater just by switching water valves and switching the selector switch on the heater.
Both thermostats on the heater work exactly the same way, and in fact they are simply duplicate thermostats with a selector switch to choose which temperature setpoint you wish to use. All other elements, functions and features of the control system are the same -- all other control components that are used in the heater are the same components except for these two thermostats. As a result, either thermostat can be used to do the same thing -- set a temperature shutoff limit.
CAUTION: Always turn off the power and gas to the heater and turn off the pool pump when attempting any repair of your H series heater.
CAUTION: The pool heater is essentially a furnace. Only qualified service technicians with proper training and tools should service the heater.
As in your case, if one thermostat does not operate, the other can be used so long as the remainder of the system operates properly. All of the other safety sensors are included in the control system regardless of which thermostat is being used. If one thermostat does not operate the heater but the other does, that malfunctioning thermostat should be replaced. Purchase part number CHXTST1930 and follow the instructions in the package to replace it.
Here's a suggestion: I have found that rotating the thermostats fully counterclockwise during the off-season tends to increase the life of the thermostat.
During the life of your H series heater maintenance needs to be performed due to the dirt and corrosion. The manual recommends cleaning the pilot (or ignitor/flame detector) and the burner tubes once a year, as well as a general cleaning of the various components. Similar to a home furnace, this cleaning helps keep the various systems functioning properly. Occasionally some components will wear out and need to be replace.
Over time the inside of the burner tubes will collect dirt and rust particles. Your manual provides instructions on how to remove the burners for cleaning. This procedure is a bit tricky, so if you're not inclined to repair things (like your furnace) it would be wise to have a professional do this cleaning. In other words, head the cautions listed above. The burner assembly can be disconnected from the heater for cleaning without disconnecting each burner tube. I recommend using a 1.5 inch with 16 inch handle brass tube brush to clean the inside of each burner tube. Material caught in the tube might be difficult to get out -- use a vacuum, then shake with the inlet side down, then vacuum again. You'll know you have removed all the debris when as you shake the assembly it no longer rattles. The exterior can be cleaned with a brass wire or tough nylon bristle brush, then wiped with a soft cloth. Inspect the burner tubes carefully, looking for any cracks or broken welds. If damaged, replace with HAXBRN1930 burner tube. DO NOT USE A DAMAGED TUBE! This can lead to serious problems with your heater and/or danger to those who come in contact with it.
Another source for flame problems is the gas orifices -- especially propane orifices. The gas orifices are located in front of the main burner tubes. Especially in the off season, insects love to wonder in the orifices and build nests, or spiders will build webs. Natural gas orifices are larger and less susceptible, but propane orifices are much smaller and should be checked and cleaned often. A standard household pipe cleaner works well for this job. The orifices point toward the main burners, so it's tight going in this area.
If your heater has a standing pilot (MV series, has a small flame on all the time), it also should be cleaned periodically -- annually is the manual's recommendation. Again, the manual illustrates a procedure to dis-assemble, clean, and re-assemble the standing pilot. The pilot is a little burner, just like the larger burner, so it needs to be clean of dirt and corrosion. It has a manual spark generator. You should be able to hear or see the spark as you press the manual spark generator. If not, the manual spark generator may need a new battery (if so equipped), gap adjustment, or may need to be replaced. The standing pilot has a flame detector. Both the spark tip and the flame detector are constantly in the flame, so they need to be kept clean of corrosion. Use an Emory cloth to gently clean these metal components. If any part of the standing pilot assembly is damaged, replace it with a new part. Consult your manual for standing pilot component parts.
If your heater has an electronic ignitor (ED series) your heater does not have a pilot. Rather, your heater uses a electrically generated spark and a flame detection system to start combustion and monitor the flame's presence. The ignitor has two metal prongs that need to be kept clean and free of corrosion. Your manual illustrates dis-assembly and re-assembly procedures. Use an Emory cloth to gently clean the two metal prongs. The gap between these two prongs is important -- should be 9/64 inch between the closest points. Also, the distance from the ignitor/flame detector to the main burner tube is important. If you see distorted prongs (not straight, different angles, etc.) suspect that the prongs have been damaged. If the ignitor is damaged, replace it with a new ignitor assembly HAXIGN1931.
Now back to operation. I suspect you have an ED series heater (electronic ignition) since you describe a "clicking from the control module". The clicking sound may well be coming from the electronic ignitor (HAXIGN1931). If true, then the system is attempting to initiate combustion. Combustion start steps are: 1. permissives active (yellow LED ON in some models) AND thermostat active (either spa or pool depending on selector), 2. controller starts spark and opens gas valve (green LED ON in some models), 3. controller senses flame detection. 4. If flame is not detected within about 3-5 seconds, controller closes gas valve and stops spark (green LED OFF in some models). 5. If flame continues to be detected, controller turns off spark but leaves open gas valve until either permissives or thermostat goes inactive (OFF). 6. If any permissive goes inactive (OFF), yellow LED goes to OFF (in some models) and combustion is inhibited.
Now to trouble shooting: You describe a "clicking" but the system would not go into combustion. As you can see from the combustion start steps, the likely fault is that the controller cannot detect flame. This typically points to either: 1. No fuel (valve closed, etc.), or 2. flame detector malfunction. First make sure you have fuel, valve open, etc. Next verify that the heater gas valve does actually open. You should hear a metallic "click" as the heater gas valve solenoid operates. (If you do not hear this metallic click, the gas valve or the controller might need to be replaced, or the wiring between them might be broken or disconnected.) In the first few seconds you might not see any flames since the gas needs to travel down the burner tubes to the ignitor. Once combustion initiates near the ignitor, the flame will propagate throughout the burner set rapidly. On this model the flame is difficult to see. I recommend setting a mirror on the heater floor before initiating combustion, then remember to remove once flame is off.
If you've check the fuel and are certain you have fuel to the heater, then the likely fault is in the ignitor/flame detector. The controller provides about 3-4 sparks per second to the ignitor during combustion initiation. You should hear a rapid "clicking" that sounds like the snaps of static sparks. Since you hear a "click", you're probably getting spark but might not be getting flame detection. If the cleaning and adjusting procedure above does not solve the problem, it's likely the assembly needs to be replaced.
As I mentioned above, the gap between the metal prongs on the ignitor assembly is important. Too-wide -- might lead to spark but no flame detection. Even wider -- might lead to no spark at all. Over time the prongs may distort slightly due to combustion temperatures. If left uncleaned or unadjusted, the ignitor will sooner-or-later malfunction. Additionally, corrosion of the metals, both at the spark gap and at the ground base, can lead to higher resistance in the circuit. If the heater is operated outside, corrosion of the metals will be accelerated due to moisture and other contributors from plants and insects.
Oct 11, 2012 | Hayward Pool Products Hayward H250 250k...
Kenmore Water heater, Model # 153.339462, Pilot lights, burner burns for approx. 10 - 15 minutes then both go out. after which it is more difficult to light the pilot. I need ideas please
Clean combustion parts, clean air intake, get more air to water heater and see if problem continues.
Look at color of burner flame and pilot flame: if flame has yellow-and-orange instead of clear blue flame, then combustion parts need cleaning.
Pilot and burner problems can be caused by bad thermocouple, thermocouple not sitting in flame, weak pilot flame due to dirty tube or low gas pressure, air in gas line, no draft up vent, backdraft coming down vent, dirty combustion parts, clogged air intake, insufficient air, insufficient air quality, hot attic, bad gas control valve, etc.
Open following link for pdf resources, and illustrations for cleaning combustion parts, and some service manuals:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Water Heaters
My oil burner works fine while firing, but when it shuts off, there is fuel oil continuing to come from the nozzle. I get flames outside the combustion chamber when this happens, and I can find no...
The check valve is inside the nozzle. If you change your nozzle the problem will more than likely go away. Oil burners require annual routine mantainence to run properly. The part that bothers me is you said you are getting flames outside the combustion chamber. If the flame is outside the combustion chaber but still inside the furnace, you may very well have a broken heat exchanger which is very dangerous and could kill you with carbon-monoxide gas. I would suggest having this checked by a qualified HVAC contractor as soon as possible.
Jan 28, 2011 | Heating & Cooling
Looking for sequence of operation for a lennox mid efficient furnace
When there is a Call for heat, the control delays ignition until combustion air
Blower operation has been proved and pre-purge period
Has elapsed. It then opens the gas valve and generates a
Spark to ignite the burners. Trial for ignition lasts for 7 seconds.
At the same time, the control begins monitoring the
Flame sensor. If the flame current is too weak (less than 1
Micro amp) or if the burners do not ignite (within the 7 second
Ignition trial), the control will shut off spark and the combustion
Air blower and de-energize the gas valve. Flame
Current should be between 1 and 5 micro amps to keep the
Gas valve open.
The control will attempt to ignite the burners up to two more
Times. Each time the control restarts the ignition sequence,
It begins with a 45 second pre-purge. If flame is not sensed
After the third trial, the control locks out. Lockout means that
The control shuts off the gas valve, spark and combustion air
Blower for 60 minutes. At the end of 60 minutes the control
Completely resets and will attempt ignition up to three times.
The control can be manually reset before the end of 60 minutes
By momentarily turning off power to the unit.
here is a link to an operations manual
http://0190acd.netsolhost.com/manuals/80MGF_Series.pdf
Nov 25, 2010 | Heating & Cooling
Kenmore twin burner.. orange flames
A <i>temporary</i> orange flame from your gas stove can also occur at peak usage times. An increase in local demand can cause a decrease in pressure in the natural gas line. If all of your gas appliances are in combustion simultaneously, this may also cause a drop in pressure, especially in older houses. If the problem persists, it is likely a dirty/clogged burner or the stove needs servicing. In general, an orange flame (on a gas combustion appliance) means incomplete combustion and carbon monoxide production.
Research Design Studio
Jul 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
AT&T Siemens S46 GSM Cellular Phone Logo
90 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
