Question about Dometic Refrigerators
Refrigerator was off for the winter. Now, nothing works. The "auto" "gas" and "check" lights never open. Nothing seems to have power. The battery have been checked, the fuses (AC and fridge) have been checked, the gas line works. it is a Dometic RM 2612. And since we switched the fuses, there is a really short blue wire that hangs by itself and there is no way to know where it should go... could you suggest anything? thank you
  • 857 Answers
These wires should go to the main board as there is no power you stated and you have mentioned that you have checked the fuse, it seems to have some disconnection with the board, you can check that out and if you dont know much about it i would recomend to counsult a repair guy.
Posted on Jul 19, 2010
  • amarie524 Jul 19, 2010
    Is there a way to test if the board is still ok?
    if I plug the fridge to an exetnsion, I'll eliminate some trouble shooting option?
I have a 2002 KIA Spectra that will not start. I turn the key and nothing happens. No lights, dash lights, nothing!!! I had the battery checked and charged at AutoZone and put it back in. Still nothing....
you always have to reset when you take the battery out or it goes stone dead. loosing power sounds like a battery going dead due to no charging. charge it up and drive it bck to auto zone for an alternator check.
Jan 22, 2015 | Kia Cars & Trucks
Siren works, but no power to instrument after recharging battery. Nothing changed on the bike, was just sitting all winter.
There should be a small fuse box near the battery with probably three fuses inside. Have you checked those?
Mar 15, 2014 | Harley Davidson Motorcycles
Domestic Dm2652 will not work on AC without DC power is this correct. We have been camping for a week plugged into 30amp power. Refrigerator worked fine then check light came on and refrigerator...
This is an RV frig correct? It SHOULD work either/or. AC or DC. If your plugged into AC then often the frig will work with that alone. DC is for when you have no AC so you can power your appliances of the battery. Maybe you have a converter (AC to DC which most RV's do) that somehow is not getting the DC to the frig.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 11, 2013 | Dometic RM2652 Refrigerator
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
I have a 04 gsxr600 and now it won't start. Dumb me I let the bike sit for winter and didn't disconnect the battery. Turn the key nothing lights start nothing so I pull the battery out charge it reads...
Sorry to say, your battery is dead. The reading you got was under no load conditions. Put a load of about 50 amps across it and the voltage will probably fall to just about nothing if even your lights are pulling it down to probably about 8 volts. Only one solution here - you have to replace the battery.
Mar 17, 2011 | 2004 Suzuki GSX-R 600
03 Honda Pilot Check Engine Light
yes reset by removing fuse or disconnecting battery make sure you have radio code if disconnecting battery. Problem may be oxy sensor in exhaust.
Jan 21, 2010 | 2003 Honda Pilot
98 Ford Mustang GT won't start
Pull the battery and have a parts store check it to see if it has a bad cell or two. It is possible that even though you charged it, the battery just won't work for you. Hope that helps.
Mar 14, 2009 | 2008 Ford Mustang
Bmw r 1100rt 1998
Check the battery with a voltmeter. If it drops below 11v while the key is on or you are trying to start it the battery is faulty. You can also try connecting jumper cables (I would do so without the donor vehicle running), if the instruments & lights work while cables are connected your battery is the problem.
Mar 01, 2009 | 1998 BMW R 1100 RT (ABS)
Power is on but nothing is working, not cold ,no water, no ice
Sounds like the unit needs a reset of sorts, Get your food into another refrigerator or ice chests and unplug the unit. let it stand open for several hours (just in case the vents are iced) and then plug it back in.
Jan 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Jun 13, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
43 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
