Question about Kenmore 24032\24036 Top Load Washer
Basket doesn't spin in spin cycle
The machine does everything correctly except the basket does not spin in the spin cycle. What is the problem?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Three possibilities: since you can hear the motor (Ranging from easiest to messiest) None of the suggestions are very expensive.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
If the motor coupler is OK, the problem could be the clutch:
Sears has a replacement clutch band kit.
See the following for how to pull the pump, motor and transmission.
You DON'T HAVE TO PULL THE AGITATORS OR TUB.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137&osCsid=65fc1c013d6130868b14c8bb4baf7bfd
Also see the Whirlpool / kenmore service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Both the Motor coupler (available from most appliance parts stores) and the clutch band kit are relatively inexpensive.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If the Motor Coupler is fine, and the clutch bands and springs are OK the problem could well be the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for transmission operations on top load direct drive washers.
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jul 20, 2010
"2007 Whirlpool Cabrio HE top loader with glass lid" sat for 3 months, now it does everything except agitate, and flashes
The OL error code indicates that the washer is overloaded. If the washer is not overloaded, this would indicate either a drag on the drive system or the control board is failing. Be sure nothing is on the floor under the washer that could be causing a problem. Raise the lid & manually spin the basket, it should spin freely. If not, you may have an item stuck between the spin basket and the washer tub. The image below shows how to remove the spin basket. If you unplug the washer and follow that procedure, you may find the cause of your problem.
Here is the document to help you.
Oct 14, 2012 | Whirlpool Cabrio Washing Machines
I have a Maytag Ensignia model MAV2757 AWW. The washer basket doesn't balance, even with a small load, and turns off due to the weight being unbalanced. The springs are there and oiled, the hardware...
Snubber ring that tub and spin basket assembly sits in is most likely worn. Very inexpensive part but extensive labor involved. I would suggest calling a competent service tech.
Nov 14, 2017 | Maytag Ensignia MAV2757AWW Top Load Washer
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
Basket does not spin during rince cycle
does it drain/this will tell you if you did the lid switch correct-mike
Jul 17, 2009 | Kenmore 22422 Top Load Washer
Will not spin, therefore will not drain
Hey Joe,
Let’s check to see if the wash basket will rotate CCW in Spin Only Cycle with no clothes in the wash basket
1. Open the lid and rotate the wash basket by hand Counter Clockwise, CCW. The wash basket should rotate freely with no restriction. The wash basket will not rotate Clockwise, CW by hand.
2. Raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. Raise the top of the machine to observe the wash basket and tumbler action described in step 3. (See page 33 of the Service Manual for putty knife insertion point).
3. With the top raised start a Spin Only cycle with no clothes in the wash basket, observe the wash basket it should begin to rotate CCW does it?. Watch the tumblers, they should not rotate in spin cycle (maybe ½ turn at the start of spin cycle and that’s all). If the tumblers rotate while the wash basket is rotating you have a clutch malfunction. If the basket does spin CCW and the tumblers are rotating then you have a broken clutch spring. Let do those checks and observations and see what the next troubleshooting steps will be. Rich
Apr 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
185 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
