Question about Samsung Quiet Storm 9048R Bagged Canister Vacuum
Samsung Quiet Storm Canister Vacuum VAC-9049 The motor will not run. Power is on to the motorized rug tool. How can I remove the upper housing to get access to the motor? I have removed the six visible screws, but the housing is restrained at the rear. I suspect there are additional screws under the power switch and cord retractor assembly, but I cannot remove that either. HELP!
  • daltm Jul 19, 2010
    Removing all visible screws does not free up the housing cover. One message indicated that there were screws holding the main cover assembly that were hidden under the cord rewind switch plate. He could not remove that assembly which houses the power switch and cord rewind paddles (?). There is one screw holding this subassembly to the main housing cover, but it is restrained by some hidden latch/post/tab. He drilled holes through the paddle to reach the screws.
    Guru:
  • Samsung Master
  • 468 Answers
Hi Daltm,
Thank you for contacting Fixya. This is Anil.
I understand that you need assistance n opening the Samsung Vaccum VAC-9049 motor. I will be glad to help you with it.
Please go through the link mentioned below:
http://downloadcenter.samsung.com/content/UM/200304/20030401085457984_DJ68-40015K(EN_ES)0.6.PDF
I believe the above resolution should resolve the issue, however, if you need anymore assistance, please feel free to contact us. We will be glad to help you.
Thank you. Have a Great Day.
Regards,
Anil.B.R
Posted on Jul 19, 2010
  • 2,272 Answers
The entire canister of the vacuum assembly houses the motor, vacuum cleaner bag, filter, power switch, and even a retractable cord assembly in some models. The motor is housed in the front, followed by the filter, and then the bag behind it. The switch is mounted on top just above the motor and below the cover. Each canister vacuum model is different and accessing the motor may or may not require tools to get the job done.
Before getting down to the specifics of motors, first unplug your vacuum cleaner to avoid injury such as electric shock. Next, detach the hoses. The filter and bag are the next things to be removed and they are easily accessed by pressing in some plastic tabs or untwisting a simple lock on the back cover. What is left unexposed is the motor and it typically has a screwed-in cover encasing it for protection.
Using a screwdriver, carefully remove the screws holding the canister motor cover on. Usually, the power switch assembly is exposed first. This assembly is sometimes mounted onto the motor cover plate itself with screws. Remove these screws and set aside the switch assembly to expose the motor cover plate. Again, screws are likely holding this cover plate in place, so they must be removed as well. Now the canister vacuum motor is exposed.
Once the motor can be seen, inspect it for broken wires, loose connections or even worn insulation. Sometimes, dirt and dust accumulates inside the motor causing problems. Using a can of compressed air; blow out the dust and use a small soft brush to clean the area.
Check out.Thanks.
Weak suction strength
several things to look at. first, did you change the bag?. next, check the belt on the head unit. next, check the wand for a clog. some vacuums have several filters near the motor. check those too. good luck to you.
Feb 06, 2011 | Samsung Quiet Storm 9048R Bagged Canister...
Motor/Fan does not run. I have removed and taken the top of the canister plastic motor housing apart and tested for power. I have power through the cord to the switch and power from the switch to the two...
Sorry to read about your problem, I hope this helps you out.
Well you can order a new motor at shop vac, check out this link.
you dont have to remove to check the motor, just connect power to the motor leads
www.shopvac.com/support/
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Shop Vac QPMH450 Canister WetDry Vacuum
Numatic gve370 canister wet/dry motor gone noisy
Try blowing out the motor housing with commpressed air through the cooling vents as it is running, if that dont quiet it down it may be the bearings are dry and need to be oiled, use 20w 3 in 1 oil in the blue container.
Nov 11, 2009 | Numatic GVE370 Canister Wet/Dry Vacuum
I have a torn hose on my Samsung Quiet Storm should I try to repair or toss it. Mfg no longer makes replacement hose
The early hose on these was prone to tearing. If you are careful you can shorten it once. Beyond that it will become too short to use on the vac properly. This hose was copied from the original Black and Decker hose and power head kit and was likely upgraded by a flex vinyl molded hose which should be more resistant to tearing.
Some vac shops carry hose "refills" and a Samsung dealer may have one in stock even if the hose was discontinued. The vac is good quality in its general design and worth fixing although the original diameter of this hose may be tough to match
Oct 30, 2009 | Samsung Quiet Storm 9069 Vacuum
How to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
Where can I find a part for my BV2000 in house vac? It is the smallest unit made by M S & S Systems in Dallas TX. The suction impeller is grinding in it's housing, so I need a motor/suction pump. I...
you will have to replace the whole motor as these motors where never made to be serviceable. if you take the motor to a local vacuum shop than can order you a new one. though i would recomend replacing the whole tank unit with a Nutone or Hayden they are far better systems.
Jul 25, 2009 | M&S Systems BV-2000 Bagged Canister Vacuum
Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Nov 14, 2008 | Samsung 5528R Vacuum
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Samsung Quiet Storm 9048R Bagged Canister Vacuum Logo
122 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
ray gallant
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
