Question about Hayward 1.5 Hp Northstar High Performance Pump
My pump works but there is only 2 pounds of pressure. I cleaned the filter but it won't keep the pressure.
    Scholar:
  • 78 Answers
If all valves are open, check the pump strainer basket. If that is clear, I would check the pump impeller for any debris in it. You have to open the pump but it is fairly easy. The impeller will be behind the diffuser.
Posted on Jul 19, 2010
I HAVE A MR HEATER 210'000 HEATER IT WILL ONLY RUN WITH THE TOP COVER REMOVED OR RAISED ABOUT AN INCH IF COVER LEFT ON IT WONT FIRE UP AT ALL OR IT WILL SPUTTER
This is typically due to Low Pump Pressure.
Check to make sure you input and output air filters are clean.
There is a filter under the black cover so make sure to check that one.
Turn the pressure up a 1/2 pound past manufactures setting and see if the unit starts after that with the hood having to be lifted.
Dec 22, 2016 | Heating & Cooling
2009 Hyosung GT650R fuel pump not working.
Hi, Udy the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
1. If your pump does not turn on check the pump fuse and relay and all wiring including connectors for corroded, broken, or loose pins/sockets.
1. Normal fuel pump pressure is 3-5 PSI.
2. Check any rubber or plastic tubing for age-related pinholes by removing and plugging the ends that connect to the fuel valve and then turn on the ignition switch and watch for fuel streams exiting the pinholes, if any exist, replace tubing as necessary.
3. Check for a clogged a primary fuel filter that comes off the bottom of the pump to screen out big rocks and clean as necessary.
4. Check for a clogged secondary fuel filter that's outside if applicable by removing it from the system and replace it with a short splicing tube turn on the ignition switch and recheck fuel pressure if pressure increases to normal pressure you need a new secondary filter.
5. If all the above check out OK and the pump is not functioning properly then you need a new fuel pump.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Trouble with bike starting believed to be issues with fuel
GT250R won start but cranks
HYOSUNG GT 650 Service Manual
HYOSUNG GT650 EURO 3 CATALOGUE Manual
HYOSUNG GT650 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 24, 2015 | 2009 Hyosung GT 650
How to fix pool multi pressure valve
back washing will give you the right amount of pressure when the filter is clean that is your starting pressure when it goes up about 10 pounds of pressure it will need to be backwashed
Jul 18, 2014 | Hayward SAND FILTER, PRO SERIES
2008 cbr 600 FI wont prime
Hi, Anonymous the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fuel Pump won prime
2004 Honda Cbr 1000RR no fuel prime
2007 2009 Honda CBR600RR Service Manual Moto Data Project
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Feb 24, 2013 | 2008 Honda CBR 600 RR
93 chrysler t&c awd changed fuel pump and filter, van ran fine again for about 2 months now won't start and don't hear the fuel pump. changed the oil pressure sending unit and still won
fuel pick-up in tank is blocked it has a sock over the end as a gross filter to keep out any big junk from getting sucked into the pump and causing damage to it. the sock can get so plugged up that no fuel will flow, causing the pump to run for a short time then with no fuel flow to cool it it trips the safety and shuts off
Aug 12, 2012 | Cars & Trucks
Engine loses power while driving. It acts like its outta gas but it dont die, if I slow down or stop it works fine again. I put 2 used fuel pumps in it then I put a new fuel pump in it. All 3 pumps read 35...
Fuel pressure regulator maybe . Do you know where it is on the fuel injector rail . With the vehicle running pull the vac, hose off . Does the rpm go higher ? Is there fuel leaking out the end of the regulator ?
Apr 20, 2017 | Buick Riviera Cars & Trucks
I need to know the pressure the pump should be at when on i have an aboveground pool with a waterway pump.
There is no standard pressure your pump should operate at. Instead it will vary based upon the hydraulic load of the system and it's components. A range common to AG pumps/filters is between 10 and 16. As the filter gets dirty it will rise over time and then you'll need to clean the filter. A rule of thumb is 8-10 pounds over the 'clean' pressure you should clean the filter.
John
Jun 28, 2011 | Waterway 1 HP HiFlo Above Ground Pool Pump
On first crank fuel pump doesnt hold pressure and has to be cranked on for several seconds
sounds like its not working properly, the fuel pump pumps or it does't, then goes to regulator this is where pressure is adjusted. check fuel pressure with gauge, sometimes even new fuel pumps don't pump enough fuel. most fuel injected cars have over 50 pounds pressure.
Mar 15, 2011 | 1999 Pontiac Sunfire
2003 Honda STX 1300 Pan European fuel pump not starting
Hi, Rolf_stuber the following is a systematic procedure for diagnosing fuel pump issues designed to keep "DRACHMA" to a minimum. If you need parts check with Amazon and eBay first to keep costs down.
Thread Fuel pump refusing to prime pump
Fuel Pump won prime
Honda 2003 ST1300 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 2003 ST1300lA Owner Manual
May 08, 2010 | 2003 Honda STX 1300 Pan European
No more then 30 pounds of presure and wont shut off. Flotec water
If the pressure does not get pass 30 psi, then check for leaks along the pipelines and on the tank itself. An air leak on the top portion of the tank can cause the pressure not to trigger the pressure switch. Use soap bubbles to detect any air leak. Although a stuck pressure is not more likely the problem, check it also.
Aug 31, 2009 | Flotec 1/2 Hp Stainless Steel Waterfall...
Hayward 1.5 Hp Northstar High Performance Pump Logo
55 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
