Question about Maytag Admiral Top-Freezer Refrigerator
Both the fans are running but it won't stay cold
  • Maytag Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerBoth the fans are running but it won't stay cold - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 19, 2010
Car won't stay running
If the problem only happens when the engine is cold, a bad electric sensor is likely to blame. If the car stalls even when the engine is warm, the cause is likely a faulty electric fuel pump.
Why is it that my car starts but won't stay running? ' Reference.com
https://www.reference.com/vehicles/car-starts-won-t-stay-running-6449388a9326285d Car won stay running Google Search
Dec 15, 2016 | Cars & Trucks
Msd3756aew fridge won't stay warm, freezer cold but not keeping frozen. Cioils not frozen, fan working
the ptc overload/relay on the compressor is bad and not starting the compressor,remove back cover unplug the ptc off the compressor and replace it with a new exact replacement part
Feb 01, 2013 | Refrigerators
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Fan won't stay running and temperature sensor flashes
Sounds like the fan needs replacement. A faulty fan will shut the set down and the tem light will falsh in most cases.
Oct 27, 2012 | Televison & Video
What causes the coils behind the panel in the freezer to freeze up and stop the freezer fan? top half of freezer defrosts, lower half stays cold.Fridge is side by side and freezer fan keeps turning of
When the evaporator fan motor stops running the top half of the back wall of the freezer will frost over and the the only reason the lower portion stays cool is because cold air falls. More than likely you have a a dc motor fan and its bad, but be wary with ge, the main control board could also go bad causing the fan not to run.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | GE Refrigerators
Is it the engine cooling fan or some type of fan relay switch because my fan stopped working and jeep overheats when idling or at speeds below 30mph while A/C is on.
I would look to the electrical side of the fan operation. You have three basic components to the cooling fan operation...the fan switch, the fan relay, and the fan motor. You need to determine what part of the system is not working. If you can run a 12V jumper wire to the motor and it works you know it must be either the switch or the relay. if you jump out the switch and the fan runs, you know it must be the switch.
Feb 09, 2018 | 2005 Jeep Liberty
89 accord loud lots of fumes and won't stay
It sounds as if you might have a vacuum leak (fumes and running cold) and an exhaust leak ( loud)
Dec 13, 2011 | 1989 Honda Accord 4 Door
The refrigerator part is not staying cold. The freezer is wrking correctly and is freezing food. I vacummed all the dust out of the back but the refrigerator is not staying cold. It is running...
This can be a defrost problem or the fans may not be running. If the fans are not running then check the fans. I would need the model number to tell you if you have an electronic model or not because checking the fans is a lot different.
If it is a defrost problem the back wall of the freezer will be covered with ice.
This website has very good info on thses problems
http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 24, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Heater won,t blow warm . core ok. fan runs .will only blow cold
EITHER VALVE STUCK TO ALLOW WATER IN MATRIX OR YOU HAVE AIR BLOCK IN IT. TAKE OFF TOP HOSE AND RUN MOTOR, TOP UP RAD AT SAME TIME, USED A DESCALANT IF WATER MUDDY /RUSTY LOOKING
Feb 02, 2009 | 1997 Dodge Neon
Maytag Admiral Top-Freezer Refrigerator Logo
60 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
