Question about GE Dryers
The dryer will heat up etc but will not spin...any suggestions?
    President:
  • 228 Answers
There is a belt that goes around the drum and is attached to a pulley at the bottom. you will need to unplug the dryer access either the front or back and check to see if the belt is tight. if its loose or snapped off, you may have to purchase a new one. it's cheaper than replacing it with a new dryer. good luck!
Posted on Jul 25, 2010
Testimonial: "Perfect answer!!! "
Dryer won't spin
Someone is going to have to get inside to see if the belt (it should have one around the drum) is broken or the motor that drives it is seized, etc.
Need to see if drum turns and if too freely my money would be the belt.
Dec 05, 2012 | Whirlpool Dryers
Hello, I have Kenmosre 90 series dryer. Did a load ealier today, and it was fine. Went back to put another load in and realised NO heat was on, absolutley no heat in the dryer, the air inside is room...
you may need a heating element. You can go to your locale appliance store and buy the element & install it yourself . Just make sure you take All your dryer info, (etc; the dryer model, make, yr & the serial # ) this info is easy to find, its located inside the dryer door. Just call around your locale area and ask them how much it is for the heating element, for your dryer. It should be rather cheap compared to the cost of Kenmore appliance company coming out to fix it for you. The heating element is rather easy to install. I have installed a few in my own dryers and in my hot water heater.
Thank you.
Sincerely,
cat2868
Jan 28, 2011 | Kenmore 62802 Electric Dryer
My dryer will spin etc.. no heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 30, 2010 | Whirlpool Dryers
Maytag dryer stopped heating /drying
ON THE SIDE OF THE BURNER TUBE THERE IS A RESET THERMOSTAT- IN THE CENTRE U PUSH THE BUTTON.
Jul 08, 2009 | Dryers
Won't heat
If it spins - you have a problem with the heating elements (usually they are 2 heating elements).I suggest you call a tech and have the deffective elements replaced
Apr 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't spin
low voltage to the motor or a bad motor
Dec 03, 2008 | Dryers
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Washer - yes, dryer - NO!
may be as simple as a broken wire to the dryer heat element, take the top off & check if you have 240 volt supply to the dryer heat element
Oct 16, 2007 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
123 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
