Question about NEC ND-3550A-KIT DVD±RW Burner
Can't read burnt dvd's
My ND-3550A can't read burnt dvd's. The drive shows as if the dvd disc is a common cd and got total size of 0 bytes and free space of o bytes but when I open it, it shows no files tho I know there are files in the dvd.
thanx up front
email: oran_lori@yahoo.com
  • 1 more comment
  • uroradman Sep 16, 2008
    The drive works great as a CD only drive. It won't do a thing with DVDs. I have upgraded the firmware to 1.07 and I am informed that no special driver is needed other than the standard Windows driver. It is identified correctly in Windows manager. I have used diagnostic from SysyemSuite 8 and it fails miserably for DVD tests, but does well with CD tests.
  • jugo55 Oct 09, 2008
    with "cd" and "dvd+" is ok but "dvd -" read like blank cd
  • wonderdog16 Dec 31, 2008
    I have this exact same problem and it seems that everywhere on the internet i go to find a solution, there are the same "solutions" posted. No one has found a fix for this short of completely reinstalling windows, and that doesnt even work all of the time. The problem is not with a certain type of disc, or it not being closed properly, or the write speed. The problem is the drive just ceases to read DVD disc of all sorts. For some it starts as only one type of disc, usually burned ones, then will become all DVD disc, burned or movie/game.
    My drive started out superb, best drive id seen in a long time. Read and burned everything it was suppose to. Then about a year ago, maybe closer to 2 now, it quit reading SOME burned dvds that it had read fine prior to then. Then it became all burned DVDs. Then, when the new FFXI expansion came out, i inserted the DVD to install it and it would not even recognize the disc was in it. Disc read fine in other drives, tried 5 of my other friends game disc, would not recognize any of them. I tried a regular DVD movie, it would not recognize it. not a single DVD will read in my drive now, and i am furious as the problem semed to happen right at the end of my warranty.
    Myself having a bit of electronics schooling and understanding, decided to opent he rive up and see if maybe something had burned out, or if the DVD lense had warped or something. Tested and checked EVERY SINGLE item in the drive, they all were reading properly, and the lense was not warped/cracked/broken in anyway. SO i left my case wide open, reinstlaled my exposed drive to see if the lense would move back and forth to read it, and to make sure it was spinning properly. Everything worked fine on the drive. The problem has to lie somewhere else, and it is being led to believe it could be a registry problem caused by trying to copy or burn some copyrighted stuff. As a fresh install of windows usually fixes the problem, this would lead me to believe it to be true.
    I however, have no spare disc drive and since my drive wont read ANY disc at all anymore, DVD or CD, I can not reinstall my windows xp at this time. So i have to wait til some extra cash flows in to buy a new drive all together. Hope it helps, or atleast can lead someone on the right path to finding a solution.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 137 Answers
Try reading the DISC on antoher PC or DvD Rom to see if your deductions are correct, check your installtion again and confirm correct driver installed. You can find the installtion Guide here:
http://support.necam.com/Optical/NEC_DVD_CD_quickstartguide.pdf
As last outcome/ option Try a firmware update here: http://support.necam.com/Optical/downloads/FlashFirmware/
Hope this help
Regards
Hands of Time
Posted on Apr 21, 2008
    Novelist:
    Champion:
  • 202 Answers
These kind of problems occur commonly when u use non branded DVDs, which are not fully understood by ur DVD authoring tool.
The easiest solution would be...Try writing in speeds lower (less than half) of what is specified on the disc
Hope this solves ur problem!
IF not, u may have to consult ur drive supplier...Anyway try using good DVDs atleast once before u take it for repair
bye
    Champion:
  • 207 Answers
Every CD is burnt. If it reads for instance original installation CD's or audio CD's than the problem isn't in DVD ROM but either in a type of DVD (-R,+R...) or the problem is caused due to fact that DVD wasn't closed after burning on another computer.
In my computer it sees the dvd player, but when i put in a dvd or cd it does not play
if the size of the disc is showing 0 bytes and dvd is not read, try cleaning the lens of the drive and if it does not read the dvd, then try upgrading the firmware of the drive from
http://liggydee.cdfreaks.com
Jun 16, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
LG DVD recorder no longer detects any discs in the drive
do one thing change the Bus cable of lg dvd writer, then check if the problem persists check the drive on some other system, if the result is the same the fault is in the drive
Sep 17, 2009 | LG (GSA-4166B) (GSA4166BB) DVD RW Dual...
FILE SYSTEM RAW in cd properties and cant access blank cds,dvds
A blank disc is RAW until something is burn to it the burning program will format it to cdfs.
Jul 30, 2009 | NEC ND-6750 DVD±RW Dual Layer Burner
My nec 3550a wont pickup a burnt dual layer disc
It may not be compatible with a dual layer disk, just the regular dvd-r or dvd-rw disks.
Jul 19, 2009 | NEC ND-3550A DVD RW Dual Layer Burner
Blank DvD Disc Reading Problem
Goto HP's website to the support section download the drivers and replace your current ones. If it still does not the drive has failed and needs replacement.
Thanks Frank Z.
http://www.codebluehelp.co.cc
3868607368
Jun 29, 2009 | Computers & Internet
My philips sdvd8820 don't burn movie
what is it your trying to burn?
Nov 28, 2008 | Computers & Internet
Cd writting and reading
you can open a .iso with power iso or alcahole120% this will install a virtual drive you can mount your image on this will act as a pretent disc so you can cheack your file is working before you burn it you can also burn it with this softwear think of a .iso as a zip file
Oct 17, 2008 | LG GCE 8240B CD-RW Burner
Samsung make TSSTcorp CD/DVDW SH-S182F
on creation or compilation of any cd/dvd regardless of disk format or capacity. the finalizing of a disk. will write a TOC ( table Of Contents ) this will inform the drive reading the disk. whats on it. even if a cd or dvd writes 1 track of music. if thats all you put on the disk, and finalise it. that will be the finished capacity. if you use rw disks. you must format the disk before re-using it.
this will completely erase all previous data on it.
If as stated you are using Nero. there are setting options, to create a multi-session cd/dvd whereby you can add additional files at a later date. however this disk will not be readable, by any other computer-cd/dvd player. until the disk has been finalised, and produced the Table-Of-Contents. ( Index )
Mike @ Compurepair.
May 10, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
E drive - D drive not reading blank discs
i'm assuming your drives are dvd compatible? Got the right drivers for them?
check here for that
Mar 09, 2008 | Dell Dimension 4600 PC Desktop
Open Questions:
Toshiba Customer Care Number Toshiba Toll Free Number 'call +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 20, 2018 | Toshiba Computers & Internet
See all NEC ND-3550A-KIT DVD±RW Burner Questions
NEC ND-3550A-KIT DVD±RW Burner Logo
240 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
