Replacing phaser 8200 lamp
Can you please send me the instructions for the lamp replacement.
Thank you,
Bill Niedermeyer william@legacytechgroup.com
  • 2 more comments
  • johnron22 Aug 05, 2008
    Can you please send me the instructions for the 8200 lamp replacement.
    Thank you,
    johns@computersupplypeople.com
  • Anonymous Oct 22, 2008
    can you email mail the instructions too? I just got the 15,004.45:8007 code.
  • CPService210 Nov 13, 2008
    I have the same problem. Could you please send instuctions.
  • cjpparker Jan 25, 2009
    I have a phaser 8200 - with bad lamps and need directions on how to replace - already have the bulbs
    Thanks
    Connie@quasithought.com
    President:
  • 2,072 Answers
Done via e mail. Give yourself an hour to do this.
Posted on Apr 21, 2008
Xerox phaser 8200 fault code 15.004.45:30386
That is a drum heater fault code. The drum heaters are 2 ,,, 150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps. Let me know if you want me to send you info how to change them.
rak458@aol.com
Mar 09, 2010 | Xerox Phaser 8200 Laser Printer
I get an error message that says "Printer Error - Contact Service: Report Fault: 15.004.45.1758" Whats does it mean and how can I fix it? Thanks
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,, rak458@aol.com
Jul 14, 2009 | Xerox Phaser 8200 Laser Printer
Error Code: 15.004.45:113654
That code means the drum heaters are not working.
The good news is, yes you can fix it yourself.
The drum heaters are 2, 150 watt halogen lamps. One or both of them have blown out. If you want drop me an E-mail at rak458@aol.com
I will send you instructions how to replace them.
It would take 1 to 1 1/2 hours if you have never done it before. Lowes, Home Depot or any place that sells halogen lamps would have them.
I however, do highly recommend, if you can find them. Sylvania halogen lamps rated for 130 volts and have vibration protection. They cost slightly more, but well worth it. Besides even if you get those, you have less than $15 in the repair.
Let me know, I will send you the info. That's all your problem is.
May 06, 2009 | Xerox Phaser 8200 Laser Printer
Printer error Contact service Report fault 15,004.45:40227
There are 2 , 150 watt halogen lamps in the drum heater assembly. One or both are burned out.
I can send you instructions on how to replace them. Xerox will want over $250 for an entire heater assembly. You can buy the lamps at Lowes or any place that sells Halogen lamps for around $15 for a set.
May 05, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
Fixing the lamps of xerox phaser
Are you asking about a Phaser printer. Like a Phaser 8200, 860 ?? Just want to be clear on what info I am sending. But I would be glad to send you the directions.
Sep 23, 2008 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
Error Code
The normal cause for that is the drum heaters are not comming on.
The easiest way to check for that is to turn the machine on, preferably with the lights off in the office. When you turn the machine on, leave it on for a couple of minutes and look into the openeng where the fan is. You should see the lamps glowing in that opening.
If you don't. Those lamps need replaced. They are simple 120 volt 150 watt halogen lamps you can buy at Lowes or any store that sells halogen lamps.
They are bit time consuming to replace, but if your pretty decent in doing mechanical things, let me know I will write up the procedure for you. Just takes more patience then know how.
Mar 31, 2008 | Xerox Phaser 8200 Laser Printer
109 people viewed this question
jasbo
jasbo
