Question about Dometic Rooftop RV Air Conditioner
The a/c unit on my fifth wheel,fan runs but does not blow any cold air
  • Dometic Master
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 19, 2010
Why did SPT Portable Air Conditioner stopped blowing cold air?
Unit needs to be taken apart and washed out , also check to see if motor turns freely by hand , clean base of unit fans / blowers and drain ports / channels . Check outdoor motor to see if bearings are tight or fan overheats and cuts off if so replace outdoor motor .
Oct 04, 2014 | Heating & Cooling
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
My outside unit wont start. the inside fan is running but just blowing normal air, not cold?
check you contact on your outside unit, the relay may have gone bad. In the corner remove four screws, and the cover should come off it may have a fifth in the middle. It is a black square, T1 T2 T3 and L1 L2 L3 , it has a relay in between. Make sure you have you voltage coming in(line the L's), if you don't then somewhere around the unit is a box check and make sure the fuse/breaker is good. If you have power, with an insulated screwdriver or you finger push the contact in, the compressor and fan should run. Now if the relay is engage then it is more then likely the fan motor or capacitor. Hoped this helped tim
Sep 03, 2010 | Goodman CKL42AR42 Air Conditioner
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
Central air unit problem.......It starts out blowing cold then will only blow room temp air after some time. I don't see anything freezing up..Filter is clear. The unit outside is not clogged up. The...
Check your outside unit to see if fan is running. If it is running check to see if air is blowing out if not you have a bad capacitor. Some times if a capacitor shorts out the fan will run backwards and the line will get very hot same as if the fan is not running. Russ
Jul 20, 2009 | Heating & Cooling
Keeps tripping breaker when running ac
you need to check that the breaker it rated high enough for the ac unit
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Fifth wheel A/C PROB
Most probably your unit has no more refrigerant charge. Being unused for 8 yrs will cause leaks on seals.Locate for the system sight glass, run your a/c,if you don't notice any bubbles nor liquid appear on the sight glass your unit runs out of refrigerant.Hope some of this information helps you.
Sep 11, 2008 | Dometic Rooftop RV Air Conditioner
AC Compressor
Check your CONTACTOR - the black "block" where all the line wires connect. Sometimes they stick. It's a cheap part, although make sure you take a pic of the contactor with all the wires attached BEFORE you take the wires out to get a replacement.
Aug 02, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
521 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Jay Finke
Jay Finke
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
