Question about Saeco Vienna Digital Coffee Maker, Espresso Machine
I have saeco coffee machine cap002a ,when i turn on the machine the screen show self-test temper. error ,it's not working at all!
  • kym beesley Sep 21, 2013
    what could it be
  • Anonymous Mar 19, 2014
    Self-testing cycle
  • 515 Answers
I think you need to take it to a Saeco service center.
It can be the circuit card that is the problem.
Posted on Jul 11, 2008
Error 1 - How to Resolve Grinder A Blocked?
The grinder is the problem. Inside the grinder is a white gearwheel. Change the gearwheel (cheapest way) or change the grinder and reset all errors from service menu.
Jun 05, 2014 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino must be reset I recive error mesage : error 1 I replaced grinder with a new one but the error message remained on screen and do not know how to reset
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
Oct 08, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Removing Saeco coffeemaker dregs container
The dregs container comes out with the drip tray. Lift up on the drip tray and slide it out. If this doesn't work then the brew group is out of position. Turn the machine off then on so that the machine goes through a self test. This will reposition the group allowing removal of the dregs container.
Apr 24, 2009 | Saeco Incanto Sirius Fully Automatic...
Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Aug 01, 2008 | Starbucks Saeco Italia Digital Barista...
Blocked coffee despencer
I think you have to go to a Saeco service center to fix this, it can be the electric board.
Jun 25, 2008 | Saeco Royal Professional Espresso Machine
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Saeco S-Class Incanto de luxe coffee machine not working.
If it is what it sounds like to me I had this same problem with a split pipe on my saeco vienna machine. The place tried to say I had not descaled the machine 4 times in under a year leading to the pipe bursting. This is what wrecked my machine but it could be a simple case of a hose blew off. Sounds like an internal fuse also blew. It should really be check out and should or could still work again once dry.
Jun 11, 2007 | Saeco Incanto Coffee Maker
Saeco Vienna Digital Coffee Maker, Espresso Machine Logo
282 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
