Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
No power to panel on vacuum cleaner (electrolux oxy3 system)
When I plug my vacuum cleaner into a live power point the lights on the panel on top of the vacuum cleaner do not light up. I have tried various power points that I know are working and the plug and lead connected to the vacuum cleaner appear to be in good working order. Is there something inside the panel that could be faulty and if so is it easy to have that checked out and replaced? Also the Vacuum cleaner has always had the bags and filters changed regularly and has always been reliable in the past.
Regards
Selena
SOURCE: Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Posted on Jan 08, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Posted on Jun 20, 2008
SOURCE: Repair my Electrolux 2100 cannister vacuum cleaner
On my 6500, I just disconnected the air line from the switch and now the vaccuum won't sense the bag pressure; I just have to check the bag myself now.
Posted on Jul 10, 2008
SOURCE: spare part for oxy3 system
I sought out the spare part I needed and fixed the problem.
Posted on Aug 27, 2008
  • 44 Answers
SOURCE: vacum won't ****
Do you have good suction right out of the canister without the hose attached? If so, AND your hose isn't plugged, you must have a pretty good sized hole somewhere in the hose. If you don't have suction at the canister, pull the filter cover off the top-back of the machine and remove the filter. This is where all of the air that the machine pulls in is exhausted. If something is plugged here, it will greatly reduce your suction. If you still haven't found the problem, you could have a problem with the fan assembly on the motor. But usually this is accompanied by some noise from the motor, but not always. Good Luck!!
Posted on Jan 03, 2009
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
Vacuume cleaner modle #N03052M When i plug it in
What type of unit is it...Epic, Renaissance, Guardian,etc?
Oct 09, 2013 | Electrolux Vacuums
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Power head and wand has no power. Unit is less than 4 month old.
Hi, I had the same problem with mine and found that if you plug the power head directly into the handpiece (bypassing the telescopic wand) and it worked only proved the problem is in the telescopic wand. The problem as I found was a broken terminal in the end that connects to the powerhead (female socket). As it is a non repairable part means replacement at $100AUS I have had my machine for 3 years and in this time have replaced the both powerhead once and the wand twice within 2 years of owning the machine. The wand has now gone faulty again 4 months after replacing it and consequently Electrolux only warranty spares for 3 months which I think is poor! Its a great machine but a little too delicate even if it is only used for domestic operations once a fortnight! I paid $700 for my Oxy3 3 years ago and wont be buying another Electrolux product due to poor service (customer and product):((
Dec 22, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Power nozzle N106M on our Electrolux Guardian has stopped workin
Start simplest always and work back to most difficult... so make sure you have power to the main unit, do you have a cheap voltmeter? If not they're cheap... Second check that connection plug is not stuffed with debris. Point is isolate whether it is the unit or attachment, most likely it's in the connection and repairable by you or used vacuum repair.
Aug 04, 2017 | Electrolux Guardian Bagged Canister Vacuum
Carpet rollers dont work
Hi There,
Yes, there is a reset switch on your Electrolux. This particular model also has some problems with the wands on the machine as well. Sometimes these wands will short out, preventing the power nozzle from working.
Try pushing the reset switch first to see if this fixes your problem. The reset switch is located on the power nozzle on the right hand side if you're looking down on it. It will be a little red pole, simply push this pole downwards, possible using a ball point pen is the easiest way.
If this didn't fix your problem, then it could be a few different things. The wands on your model are problematic, and should be the next thing that you test. Simply remove the wands from the power nozzle, and you can use a simply electrical tester purchased from Home Depot, and put the testers into the female receptacles on the end of each section of wand to ensure that power is getting down to the brush.
It may also be that your hose has gone bad. If you test both wand sections, and no power is getting through, remove both wand sections and test the female electrical connections on the end of the hose handle.
If you're not getting power here, this indicates that your hose has gone bad and needs to be replaced. We do carry all of the hoses for the Electrolux canisters, and most likely have the one for yours in stock. Please feel free to contact me if you need any further help.
Thank you,
Chris Jones
GoVacuum.com
May 13, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
The red light on my electrolux vacuum comes on and cuts power.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 26, 2010 | Electrolux Guardian Bagged Canister Vacuum
9 month old electrolux oxygen vacuum just quit
my electrolux oxygen canister just quit- i think it's the sumo board and the whole fuse problem why does this keep happening over and over (my 4th time w/ this model) and where can I buy a replacement sumo board myself?
Jun 19, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
463 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
