Question about Daewoo DVG-9500N DVD Player
Daewoo DVG9200N split screen in black&white - How di I fix?
My remote doesn't seem very responsive, I put in new batteries. We can't get DVD's to come up without a split screen, and in black and white. Help please???
  • 10,594 Answers
Your dvd has been set on component vidoe output mode that need to be turn Off or its System selection got wrong, procedure would be written in user manual of dvd player about how to change it, however, there are two buttons at end of remote, V-Mode and System.
Press V-Mode few times to select correct video output mode of dvd player.
Press System button on remote to select correct system video output so tv can show you correct picture.
Hope these info will solve your problem.
Thanks.
Posted on Jul 19, 2010
DVD player is black and white and screen is split
Make sure the player is compatible with your TV broadcast standards. A Pal player will show b&w pictures when connected to a NTSC tv and vice versa
Feb 26, 2015 | Samsung DVD-V3500 DVD Player/VCR
Tip
Hello to all at fixya & Tech Guy ! I have a Daewoo DVG9200N, and a Philips...
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on May 12, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
Our 13" tv has deveoped
Hello jcdcam,
Welcome, and thank you for using FixYa!
Your issue is caused but the logic control to the menus displays being "Stuck".
You can try this simple fix before following up with my next suggestion; if the first doesn't work.
Unplug power to this TV and pull the batteries from your remote for 15 minutes. Afterwards, put the batteries back in and plug the TV back in. If the picture is normal, "Yea! We win."
If the picture returns with the "Dark Menu" you will have to have the tuner control board replaced.
Have a great day!
Sep 11, 2011 | Daewoo Televison & Video
My sony dvd vhs player is displaying only black and white split screen how do I fix this? nothing is wrong with the vhs
You have the Chanel Finder activated, usually a small switch on back, or somewhere it is used to give a "Pilot Signal" so the TV set can be tuned.to that signal, after you find it, you turn it OFF on the VCR. Or maybe the remote, check in your manual.
Mar 03, 2010 | Sony SLV-D380P DVD Player/VCR
Black and White menus and playback
If you are connected on av2,make sure it is not on av2s,as this will give a b/w pic
Mar 07, 2009 | Panasonic Televison & Video
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Cannot see menu
Try pressing the P Scan button on the remote. It worked for me.
Nov 03, 2008 | Protron PD-DVR100 DVD Recorder
Black and white picture only...
You have you're video cord in the wrong jacks. If you are using composite make sure it's in the yellow jack and make sure the player is NOT set to progressive scan.
If you are using component, make sure the cables are in the RED, GREEN, and BLUE jacks, but make sure you have the CORRECT red jack (not the right channel audio out...).
Nov 08, 2007 | Daewoo DVDS151 DVD Player
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Dvd player split screen
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
May 20, 2006 | Samsung SV-DVD3E DVD Player/VCR
Daewoo DVG-9500N DVD Player Logo
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
