Question about Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
The pot on my Dynamo pool pump tightens in the horizontal position instead of the vertical position.Any ideas on how to get it to tighten in the correct position.
  • 760 Answers
I'm assuming you mean whe you thread the strainer basket pot into the pump and tighten it it ends up being 90 degrees off center? That means you cannot turn it and additional 270 degree. Unthread and wrap multiplul wraps of teflon tape onto threads. Then I'd add lightly add some pipe dope. Tighten the assembly up, but stop when it is snug and aligned. The combination tape and dope should keep it from leaking, but remember this would be a suction leak, so check carefully
Posted on Jul 19, 2010
How do i adjust the dynamo & water pump drive belt ?
theres a bolt at the bottom of the power steering pump its in two pieces loosen the top piece of it and then tighten the other bolt as tight as u can then hold it to that tightest point while tightening the top bolt
May 26, 2014 | 1994 Volkswagen Jetta
Hayward Pool Pump SP 1510 can I rotate the housing ?
No problem. Be sure toimages?q=tbn:and9gcsxyk8_ugvtk4dbhsw_znmzsxkyyed0iltvt4-u7eeckd3qkyu6 realign the pot to vertical.
Feb 18, 2013 | Pool & Spa
The strainer pot on my Dynamo pool pump keeps coming off the pump.
CHECK TO SEE IF THE RECEIVER HOUSING HAS A CRACK ALONG THE THREADS IF NOT TRY MORE WRAPS OF TEFLON TAPE
Dec 10, 2017 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Pump appears to be running properly but is not moving the water
Make sure there is an o-ring on the lid. Fill pump with water and then appy a little petroleum jelly on the o-ring and tighten hand tight. Start pump.
Apr 26, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
I installed a complete hayward filter with a new multiport valve. i can see DE in my pool. what would cause this? Thanks for your help.
If these Hayward pool filters are leaking DE back into the pool, there are a couple things that you will want to check. Check for loose bolts on tube nest plates and tighten them if necessary. Make sure that you don't have a worn or loose fitting diaphragm gasket and that there are no rips and holes in it. Replace the gasket if any of these is the problem. Check for openings or tears in one or more Flex-
Tubes and replace them if necessary.
Dec 19, 2010 | Pentair Clean & Clear Filter and Dynamo...
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Dynamo ABOVEGROUND POOL PUMP - 1.5HP - Logo
114 people viewed this question
Top Dynamo Pool & Spa Experts
Jay Finke
Jay Finke
Gil Shultz
Bosse Photos
Are you a Dynamo Pool and Spa Expert? Answer questions, earn points and help others
