Question about General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator
GE French door display error
I have a ge french door refrigerator and it was working fine until after the long distance move. I plugged in the fridge and it display the number 88 on both side. Use to show temperature and something else. Please help me!!!
  • 1073 Answers
SOURCE: GE Profile French Door bottom
IT IS STILL UNDER WARRANTY call ge at 800-386-1215 for factory service
Posted on Apr 15, 2008
SOURCE: Turn on fridge
Press the Ice Off button and the Freezer button together for thirty seconds. Set your temps at 36 for refrigerator and 0 for freezer.
if that doesn't work, press the freezer button and the energy saver button for thirty seconds and do the same thing.
Posted on May 30, 2009
SOURCE: Water dispenser quit working on GE Profile French door 'frig.
The dispensers could be clogged with mineral deposits. If you look in your care manual it talks about a water vinegar solution that you pour into the top of the despenser, let sit, and then drain it through the back. I had a similar problem and it was because some of the water that was sitting in the top of the unit(where the gallon jug sits; under the black think) was full of frozen water which was blocking the water dispenser.
Posted on Jun 19, 2009
  • 56 Answers
SOURCE: LATCH ON TOP OF FRENCH FRIDGE DOOR DOES NOT LOCK IN PLACE
you nedd to replace the door gaskets
Posted on Jul 03, 2009
  • 5 Answers
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
Posted on Dec 21, 2009
2009 GE French door refrigerator moved across the room, now does not cool either freezer or food section. Model# PGSS5PJXCSS
Be sure you have power at that plug, lights should be on if not plug something into the socket that works
Dec 23, 2013 | GE Refrigerators
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
GE Profile PFSF5NJW French door Bottom freezer. Freezer is fine. Refrigerator at 60 degrees. Unplugged for two days to thaw any possible freeze up. Refrige still at 60 degrees.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Nov 21, 2009 | GE Profile PFSF5NFW Bottom Freezer French...
New french door GE fridge that won't stay cold
If " new " is less than 1 year , you will need to call GE factory service , for a warranty repair . If any one else works on it , this will void your complete warranty , and they will charge you for a service call + parts + labor .
Nov 13, 2009 | GE Refrigerators
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Lights are on controls on not cooling
hi thanks for the question Your fridge is stuck in defrost cycle replace defrost timer. THanks for the Question The appliance doc
Sep 12, 2008 | GE PFS22SBSSS Stainless Steel French Door...
Controls not working in GE Bottom w/french doors.
I have the exact same problem with mine.  I was away for 3 months, left it running. Came back and no display.  Unplugged it & restarted it and it worked for a little while and went out again.
         Did you ever get an answer?             I'm wondering about corrosion on the door switch from lack of use, as the display is only supposed to be on when a door is open.  Yours may have been a loose connector from moving it???
Aug 31, 2007 | GE PFS22SBSSS Stainless Steel French Door...
General Electric GFSS6KKXSS Stainless Steel Bottom Freezer French Door Refrigerator Logo
59 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a General Refrigerator Expert? Answer questions, earn points and help others
