Question about Toshiba Satellite A215-S4747 Notebook
Toshiba Laptop, Satellite Model. Very slow. Suggestions? I have cut back on the start menu, still cumbersome.
    Novelist:
  • 87 Answers
Note: these instructions are for Windows XP, however the procedure is basically the same for both Vista and 7.
First start with limiting the number of programs booting up with your computer. To do this click on the "Start" button, then choose "Run..." Type in msconfig then press enter. A new window will open called the "System Configuration Utility". Click on the "Startup" tab. All of the programs that have a check in their box are set to boot with your computer. If you recognize any (like AIM or any other messengers) you should uncheck these boxes if you are okay not having them boot when your computer does. This will make the boot of your computer much faster. When you are done click "Okay" and then choose "Exit without restart". The next time you reboot your computer these settings will be applied.
Second you need to uninstall all of the programs you do not use. Click on the "Start" button and then open the control panel. Open the "Add or Remove Programs" tool. Locate each of the programs you do not use, and choose uninstall. Some things you can uninstall are toolbars and games. If you no longer use them, and you still have the CD for the game then remove the program before you keep it. Keep in mind that you can remove programs while still keeping your personal files for most games, this is a good move if you want to reinstall the game eventually.
Third you need to download and install updates for your computer. Click on the "Start" button and find the "Windows Update" option under programs. Choose express install and download and install all of the updates recommended for your computer. You will likely have to restart your computer at the end of this process. When your computer has restarted, repeat this update process. Repeat until there are no longer any updates recommended for your computer (this may take three or even four update cycles).
Fourth we will move on to making your hard drive run more efficiently. Open up "My Computer" and then right-click on "Local Disk C:" and choose "Properties". Choose the "Tools" tab. You are going to run both the Defragmenter as well as Check disk utilities from this same spot. Click on the "Check Now..." button to initiate the check disk. Check both of the boxes here and run the check disk with these options, you will need to restart in order to finish this operation. When all this is done go back into the Local Disk tools and click on the button "Defragment Now..." First choose the analyze button to determine if you need to defragment your drive or not, if it is recommended run a defragment. This whole process of optimizing your hard drive may take quite a while (just let each process run overnight).
Finally if your computer is still running slowly you need to add additional RAM to your computer. You need to find out what kind of RAM your computer requires (DDR, DDR2, DDR3...) and you can easily install it yourself. You should always buy RAM online as it is far less expensive online than it is in stores like Best Buy.
In order to keep the speed of your computer up, you need to regularly run full-computer antivirus scans with frequently updated software. Viruses, malware, and general junkware have a habit of slowing down your computer.
Your computer will now run much faster and will increase its life span significantly.
please rate my solution
Posted on Jul 19, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
What is the model.
The best way to speed up your computer is by upgrading the RAM.
And install the windows again to fix all registry issues.
Posted on Jul 18, 2010
How to unlock the bios password for toshiba satellite a135-s2386
You usually have to go into the laptop itself. There are jumper settings that allow you to reset it. Taking a laptop apart can be a very cumbersome thing to do, and you could break something. I will check on that model Here is a video to show you how: http://www.youtube.com/watch?v=SxGviSv7EoA
Aug 31, 2014 | Toshiba Satellite Computers & Internet
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
Toshiba satellite a105-s4084 makes cut off/slow motion noise when listening to anything
Try a system restore bringing computer back in time before this showed up, or complete fresh install of your windows operational system. This will prove it it's a software issue, "which should cure the problem" or a hardware problem.
Apr 15, 2012 | Toshiba Satellite A105-S4084 Notebook
I have a toshiba satellite L645D how can I format it to the factory settings like it just came out of the box.
When your Toshiba Satellite laptop goes on the fritz, there are several instances where the best solution is to delete everything and start over. If your system frequently crashes or you can't remove a specific virus, you may want to restore the laptop back to original factory settings. While the easiest way to restore the system is to use the operating system restore disc, it is possible to restore the system without it. Each Satellite laptop also includes a hard drive recovery utility that lets you restore the operating system without the restore disc.
1.Take account of any files or programs you still want to use after the Toshiba laptop is restored back to its factory settings. Transfer the files to a backup location, such as a USB flash drive or external hard drive.
2.Restart the Toshiba Satellite laptop's operating system. Wait for the Toshiba logo to appear on the screen.
3.Press the key that brings up the hard drive disk utility menu. Depending on the specific model of your Toshiba Satellite laptop, the key will either be "0," "F1," or "F8."
4.Press "1" or click "Restore Original Factory Image." Click "Yes." Select "Next" to begin the restoration process.
5.Restart the Toshiba laptop computer when the restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
6.Transfer the backup copies of the data you saved earlier back to the Toshiba's hard drive. Re-install any programs you need, such as your software firewall or anti-virus tool.
I hope you find it very helpful. Thanks.
Sep 09, 2011 | Toshiba Computers & Internet
Laptop running slow & windows not responding VISTA
backup your data and run the system recovery disks.
Nov 05, 2009 | Toshiba Satellite L305-S5877 Notebook
Toshiba Satellite no wireless and want it
Your 1415 has a mini-PC card slot for an internal WiFi card. Bottom, right hand side, in the back. Buy a mini-PCI WiFi card, click it in, connect the antennas, and you're good to go.
If you dunno which card to get, this will always work: model MPC13A-20/R. Around $10 on ebay.
Of course, USB will always work but it sticks out like a sore thumb and it's cumbersome!
Mar 26, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba laptop driver problem
find the system manufacturer and system model of your laptop by typing in your dos command. Click start menu, run command prompt, and then type dxdiag. Under System Tab, you can find the system manufacturer and the system model. You can now go to google for finding your driver for your laptop. I hope this will help you.
Dec 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Upgradation of RAM in Toshoba Satellite in A 80 model
Follow the link below to Crucial.com. It shows that your laptop can handle 2gb of ram. It is easily upgraded and takes less than 10 minutes.
http://crucial.com/store/listparts.aspx?model=Satellite%20A80%20Series
Dec 09, 2008 | Toshiba PTS53U-03K00M Notebook
Toshiba Satellite A215-S4747 Notebook Logo
285 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
