Question about Samsung NC10-14GW Notebook
NC10 netbook screen keeps "whiting out"
NC10 screen keeps "whiting out" and I have to waggle it forward or back on the hinge to get the picture back. netbook is not 12 months old yet but i'm not in the country where it was bought. Problem happening more and more often. any ideas?
    Problem Solver:
  • 15 Answers
If you have to wiggle it on the hinges then it sound like it is a bad ribbon cable connection, it it has somehow broken. There is a thin flat ribbon that runs from the pc to the display. Some patience and care will required. If at a ll possible, take it to an authorized service center, should still be under warranty. Best way to test if from one end to other (pin to pin) for continuity with a volt meter.
Posted on Jul 22, 2010
Why is my screen going white?
The high voltage inverter is usually in that area. Remove screen bezel to access it. Unplug and replug the connectors to it an see it that helped. Bezel screws are usually under paper or rubber covers that pry off.
Jul 20, 2014 | Samsung NC10 Netbook
I have a Netbook NC10 and my screen wavers all the time it has become almost unusable. I live in the Durban area of Kwa Zulu Natal South Africa
http://www.notebook-driver.com/samsung/sumsang-nc10-netbook-pc-windows-xp-drivers/
Visit the address above for your original drivers.
May 23, 2011 | Samsung NC10-14GW Notebook
I have a samsung netbook and there must be a short somewhere. it is getting worse. my screen goes completely white. if i fiddle with opening and closing a bit, it pops back up. if i take the power cord...
The symptoms you describe sounds typically like the interface cable between the netbook & the screen has been damaged due to opening & closing the laptop numerous times.
There is unfortunately no quick fix if this is the problem. You will have to take your netbook in to a repair shop in order to replace the cable.
Best wishes,
Graeme
Mar 11, 2011 | Samsung NC10 Netbook
My samsung netbook NC10 has the following problems, i would like to know how i can resolve it: 1. When i put it on charge, i cannot use it, the screen goes white 2. When i take out the charger, the...
Its mainly occur in hardware problem only.. In Western Cape South Africa also samsung service centres is available....I attached the address below go and check it there...your problem will be solved...
CG Appliances centre
no:66 st john street oudtshoorn oudtshoorn,western cape
mail address:cgappliance.centre@odn.co.za
Jan 01, 2011 | Samsung NC10-14GW Notebook
My Samsung NC10 netbook has died suddenly today, it had been working fine but hd gone to sleep autmatically on powersaving mode. On trying to reactivate, a white screen appeared and there was a constant...
The fault is in the motherboard - it can't be fixed, you will have to replace it. Take the netbook to a repair shop , this is a very complicated job.
Oct 17, 2010 | Samsung NC10-14GW Notebook
My netbook,model nc10 ,the display becomes white suddenly and tilting the screen up and down it may ir maynot return to it's normal one.
sounds like you have a problem with your screen/pc connection at the base of the hinge/keyboard. only dismantling and repairing this type of connector would repair you pc--tricky i admit.
Sep 11, 2010 | Samsung NC10-14GW Notebook
What cable connects my netbook to my tv?
Most plasma/LCD's have a PC monitor plug on it. Most laptops will have one too. (or even DVI, which is usually a white plug, and wider than the VGA cable)
Either way, i'm confident that you'll probably have the BLUE 15-pin standard VGA on the monitor and the computer. If so, buy that. If you have the wider white (DVI), it'll be even better!
Nov 20, 2009 | Samsung NC10-14ROBL Notebook
Samsung NC10 will not boot up
Take it back to the store and get the manufacturers to fix it.
Jun 13, 2009 | Samsung NC10-14GW Notebook
Samsung NC10-14GW Notebook Logo
475 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
