Question about NorStar T7316E Corded Phone
Norstar 7316 Custom Call Routing - CCR
Our phones have CCR and were operational until we changed the recording. Nothing else was changed, now the CCR Administration page says Status Incomplete and our message does not play when the auto attendant answers. Is there something else that has to be changed when the recording changes? We saved and submitted it.
5 Suggested Answers
SOURCE: on Norstar 7316 phone, what
To program a button for feature dialing. Press Feature *3, then touch the button you want to program, then touch the feature button and the 2 digit code.....
done
Posted on Apr 19, 2008
SOURCE: reset Norstar M7310 System Administration password
This works, i just did it today!!
Press Feature 985
Press the 9 Key
Enter RESETSMPSWD (73738767793) using the dialpad
Press YES
Once you have RESET the password, it reverts to the default.
See Below
If your system uses 2 digit extensions use 120000
If your system uses 3 digit extensions use 1020000
If your system uses 4 digit extensions use 10020000
Posted on Jul 03, 2008
ynotphone
  • 192 Answers
SOURCE: Automated Attendent
Norstar Voicemail for 6.0 or less
Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG:", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Record the Company DAY & NIGHTGreetings:
1. Press AA
2. Press GRTG
3. Press GRTG
4. <Display> Greeting:
5. Enter 1 for DAY Greeting --- Enter 2 for NIGHT greeting
6. Press OK
7. Press REC to record.
Posted on Mar 19, 2009
  • 52 Answers
SOURCE: when i press the intercom button there is not a
First you should make sure you have intercom key assigned to your set. Press feature * 0 this is called button enquirey then press the int. key on your set to see what that key is . If you have not int key go into programming and assign int key to set.
Posted on Oct 31, 2009
How do I turn off the auto attendant on my Norstar M7310?
It depends. Go into feature 983, default pwd of 1020000 for 3-digit extensions. Go into AA, Table, Table 1, and change the option for the AA to N. If you're using a CCR tree, you'll have to go into Table 1 and disable the tree under Morn CCR and all the CCRs that follow.
Mar 03, 2015 | NorStar M7310 Corded Phone
CCR keeps enabling on Nortel Norstar
CONTACT NORTEL we have no idea what you are doing .
Dec 11, 2017 | Lands Phones
HOW TO SET UP DIALING TO OFFICE EMPLOYEE AFTER VOICEMAIL GREETING ON MY T7316E
This is the most complicated part of the Norstar voice mail system and requires a tech or fully trained admin at site.
It is called CCR Custom Called Routing.
You need to record "thank you for calling ABC" under AA/GTG/GTG/1
You then need to build a CCR tree and record the rwst of the greeting under Path 0.
Path 1 , 2 etc is where you do the pointing.
There is too much to mention here that needs to be done.
Norstar System Coordinator guide (for any version) is your friend as well but a 2 hour service call is well worth the headache.
Aug 06, 2012 | Nortel T7316E 2-Line Corded Phone
Need user/ programming manuals for the 7316 and 7208 nortel phones
The following website will help you with the operation and programming of your 7316:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
This link will allow you to display and save a copy of the 7208 User Card:
http://telecommunications.tamu.edu/userguides/M7208_16.pdf
Finally this link will take you to a site that will have user cards for the phones as well as manuals for the programming of the Norstar Call Manager User Guide:
http://www.alphatelecom.ca/meridian_norstar_manuals.htm
These steps should allow you to resolve your issue. If you do have further problems please don't hesitate to let us know. Thank you for the opportunity to assist you in resolving your issue.
Mar 01, 2011 | NorStar T7316E Corded Phone
No one in my work place knows how to work our phones. We use Nortel Networks T7316, it doesn't help that they don't make this model anymore :/. I was put in charge on setting everything up which i've done...
The feature your looking for is custom call routing(CCR). If your using 4 digit DN's then you probably have larger office environment which I'm not sure that a CCR tree will handle efficently. To build your CCR tree, enter into voicemail admin programming, press the OTHR soft key, then the CCR soft key ehn the ADMIN key
enter in a CCR tree number, then press build At this point you would enter in the number of the path you want to build and what it will do. ex. path 1 means when I press 1 on the dialpad I want it to call Mary's extension(transfer, internal, ext 2221) When your finished building your paths you'll need to save your tree.then you'll need to enable the CCR tree under AA,TABLE, Grtg Table:1, then press next til you see CCR tree: none. Press the CHNG soft key then 1 on the dialpad and ok. That will enable CCR tree 1 to work in greeting table 1. Theres a large section dedicated to building and changing CCR trees in the Nortel voicemail manuals so don't be discouraged if you don't get it on your first try. good luck
Sep 10, 2010 | NorStar T7316E Corded Phone
Toggling between greeting 1 and greeting 2
Hi, what do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Mar 11, 2010 | NorStar M7310 Corded Phone
Re recording the CCR tree
You will have to determine which CCR tree is in use. Typically Greeting table 1 is associated with Company greeting 1 and CCR tree 1. After you log into the voice mail admin box choose "OTHR" then choose CCR, then ADMIN. enter 1 for tree 1. I believe at this point you get an admin option. Choose that and you should see "path:' Enter 0 for the path and you will see your record option. Do your recording and then choose end and save as tree 1. If you still have problems send me your email and I will forward you a cheat sheet I put together for the AA/CCR changes. I've been working on the Norstar/BCM - NAM/Callpilot line for quite soem time so there are very few things I don't know about these systems.
Mark
Mar 09, 2009 | NorStar T7316E Corded Phone
Where can i find instructions for using features Norstar M7031
The feature codes will not help you troubleshoot the system at all. But here you go:
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 08, 2008 | NorStar M7310 Corded Phone
Problems with norstar m7310 corded phone do not disturb feature
What do you want to change? What feature is programmed on the button?
(CICS AND ICS 2.0+)
*0 BUTTON INQUIRY
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*81 MOVE LINE KEYS
*82 DIAL MODES
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
2 RING AGAIN
#3 CONFERENCE SPLIT
4 CALL FORWARD
60 PAGE GENERAL
62 PAGE EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
66 VOICE CALL
67 SAVED NUMBER
69 PRIORITY CALL
72 TIMED RELEASE
74 CALL PARK
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
85 DO NOT DISTURB
88 VOICE CALL DENY
9*2 SMDR Admin
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 ACD CANCEL WRAP
904 ACD HELP
905 ACD CATEGORIZE
906 ACD RECORD CALL
Dec 02, 2008 | NorStar M7310 Corded Phone
Disabling CCR Tree on M7310
Did you try F832, then select off?
Sep 12, 2008 | NorStar M7310 Corded Phone
NorStar T7316E Corded Phone Logo
368 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
