Xerox Phaser 8400 fault code 07.010.43.75941 is it worth fixing?
  • jcoz99 Apr 24, 2008
    Worked out perfect! Thanks a lot
    President:
  • 2,072 Answers
YES. It is just a print head pivot problem.
And the most likely problem would be found by removing , ( looking from the front) the left side cover. About mid way back toward the bottom of the machine there is a stainless steel block that will have ink in it. remove the spring assembly from that block by pulling it out slightly and latching it up and to the left.
Then clean the block and print head shaft.
Secondly there is a wiper between the print head and the drum that if improperly shut off, or if there was a power failure may have tacked to the print head. You would have to remove the right and left covers, and the ink loader, where you insert the ink sticks. once you remove them you will see the print head and drum. See if the blade assembly, ( pink) ( ok ok redish) is tacked to the print head. Gently remove it from the print head and run a remove light streaks and remove smears cycle.
While in that area, you would want to check the cables to the print head to see if they are hung up on something on the machine.
That code means the print head is not moving from the home position to the print position freely.
It is common and easily resolved 99 percent of the time.
Posted on Apr 21, 2008
  • Rick Kasper Apr 21, 2008
    I re read my post, I forgot to mention. That stainless steel block is onnly about 1 inch square. Sorry I skipped that description.
Error code 13.387.48:106521 Phaser 8400 Print Count 110,000 Can this be Fixed
It can be fixed, but only by a Xerox authorised service centre. Xerox website tells you to turn it off and book it in for a service. Be prepared to pay a call out fee before hand. Here's the reference link for your error from Xerox website.
Mar 06, 2011 | Xerox Phaser 8400 Laser Printer
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
Xerox on a 8400 faults code 37004 403B25998 what does it mean
37,004 is a printhead error, specifically that a Reservoir heater isn't drawing power from the power supply.
The printhead 650-4303-00 is expensive, unfortunately.
Whit
Item, Inc.
May 06, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Service message: Fault 37,004,40:50081
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
May 22, 2009 | Xerox Phaser 8400 Laser Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400 error code
That is related to the print head heating. Normally one of the print head heaters fails which requires replacement of the print head. The other item I have seen fail and cause that code is the electronics module. Both are very expensive.
Oct 09, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400 error code
That code is a jet heater code.The most likely problem is a bad print head, the second most likely bad item is the electronics module that supplies the 40-50 volt source to the print head heater.
Sep 22, 2008 | Xerox Phaser 8400 Laser Printer
Fault code
well..it's a system error code..is this an older machine, by chance?
Aug 20, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400
That is related to the memory or the entire electronics module.
There is no specific 11,009 codes that I can find.
I am basing this on the fact that the 11 codes are all based on the memories and ECT Module.
Nov 19, 2007 | Xerox Phaser 8400 Laser Printer
200 people viewed this question
jasbo
jasbo
