Question about Samsung HT-DB600 System
When you turn player on: Screen said "Hello" , then "Protection"
    Problem Solver:
  • 17 Answers
Sounds simple... usually "protection" means that a speaker or a speaker wire is shorted out. Or that the volume is just too damned high... how loud is the receiver's volume setting? If the bass tone control is jacked and the loudness button is on, even with no shorted wires, the amp can go into protection from an internal overdrive. Might be that you just need to do like your mom says and turn it down!
If you have an ohmmeter, speaker or wiring problems are easy to test, if you don't, you can still do it all mechanically... here's how
Turn off the receiver and start by disconnecting your speaker wires at the back of the receiver. With all of the speaker wires removed, does the thing still go into protection when you turn it back on?
If not, good. If it does, find a service center.
Re-connect the speakers to the appropriate terminals one speaker at a time, turning off the receiver each time you make a connection. After connecting one speaker, turn the receiver on and see if it shuts down. If not, then turn it off and add one more speaker.
Do this until you find the culprit. Leave that suspected bad speaker's wires disconnected from the receiver and test all the rest, connecting all but the bad wires.
Now, disconnect the speaker from the other end of the bad wires and spread the bare wires apart so they don't short out. Connect the wires ONLY at the amplifier end and turn the amp back on. Protection?
If yes, the wire is shorted out somewhere. got cats?? If everything is OK, turn off the receiver and reconnect the speaker and test again. Make sure the wires aren't shorted at the back of the speaker. You really need to check all the speakers to make sure their connections are "clean" and make sure that there are no stray wire strands anywhere or that the wires aren't stripped too much so they might be able to short out. After the wires are connected to either a speaker or an amplifier, you shouldn't be able top see much of any bare wire, but you already know that, right?
Some folks strip way too much off the wire and the wires simply touch the wrong things and ... badness happens.
If all the connections are clean and the receiver still shuts down when this speaker is connected and the receiver is turned on, swap a working speaker onto these wires, leaving the suspect speaker disconnected and making sure the other bare wires won't touch anything or each other.
Back on with the working speaker... good? If so, then we're determining that the problem is probably in that one speaker. If not, then we have a deeper problem.
Reconnect the suspect speaker to the other wires and try again. Good? Then you have "fixed" the problem by cleaning up the wiring connections. If it shuts down again, then you need to fix or replace the bad speaker.
If everything works now with the volume down and such, then just use a little self control. If it's still messed up, you may need a trip to the service shop
Good Luck
Posted on Jul 24, 2010
I have owned an NAD 705 Receiver for many years, and am just now having problems (probably over 20 years old). I'm getting a message on the screen of the receiver that says 'protection' .
if the receiver turns on and operates then eventually turns off due to protection mode its because a wire is shorting out the receiver.if it doesn't turn on or goes straight into protection mode then its probably time for repairs or a new receiver.
Jan 06, 2018 | NAD Audio Players & Recorders
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
Aiwa ht-dv90
Not good protection is a special circuit in side the machine.. You will need to get the machine repaired at a service center. You circuit board has over loaded.
Oct 09, 2009 | Aiwa HT-DV90 System
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
Protection mode
the protection feature is for shock protection and will go off if one of the speaker's positive and negative wires are touching check your wiring
Nov 11, 2008 | Samsung HT-SK5 System
Write protection
Make sure hold/lock is not engaged
Right click device, go to properties, uncheck box that says read only
Apr 19, 2008 | iLO (2 GB) MP3 Player
JVC XV-THA25
Fixed it by replacing a burned resistor.
100ohm 1 wat designation PR010 on the main pcb.
Feb 09, 2008 | JVC TH-A25 System
DVD turns off with "Protection" message.
it may be becoz you are using too many things from 1 plug socket / power adapter.
Aug 14, 2007 | Samsung HT-DS1000 System
Samsung HT-DB600 System Logo
262 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
