Question about Frigidaire Refrigerator Light Switch - 5303289051
Refrigerater door won't close because lightswitch stays extended in on position. Door switch doesn't have food nor debris on it to prevent it from being pushed in when door tries to close.
  • 760 Answers
I'd remove the light switch. IT should pop out of the side. You should unplug the refrigerator first, pry switch out. Tape up terminals. Push wires into hole where you can still reach them. Plug back in and be sure door closes. If all that works, buy a new switch and re-install
Posted on Jul 19, 2010
Ge dishwasher leaking
Check the door seal carefully for accumulated food debris or grease build up. If its a built in model with a wooden door panel, make sure the door gasket closes fully before the wooden panel makes contact with the cabinet - sometimes poor adjustment here prevent s the door gasket from closing fully. Water or rinse aid leaks from the machine must be treated seriously and mended, as they pose a significant fire risk. Rinse aid tends to dissolve electrical wiring insulation!
You may need to adjust the door catch on integrated machines to ensure the door closes correctly.
Feb 03, 2018 | GE Dishwashers
Whirlpool says F80% on the screen and there is a triangle what does this mean
A F80 fault on this washer is a door lock fault. Possible reasons are Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lid is in a locked state. The lock itself could be faulty (first option) or one of the above reasons. Control could be bad, or a wiring issue. Check for debris and if clear replace the lock assembly.
Jun 22, 2016 | Whirlpool Refrigerators
The "open door" light constantly blinks Door is fully closed.
Hello Gregg;
My name is Peter. I am a retired field service refrigeration technician.
It would be nice to have a model number. The model number. It is located on a label on the fresh food section wall near the top.
There re several different door switches. Some are mechanical and some are magnet.
Open the doo, push on the light switch. Does the light go out?
If not it is a bad switch.
Food storage problem - You food must be within the confines of the racks. If they extend beyond your door will not fully close.
Send me a model number so I can see what you have.
Dec 26, 2014 | Refrigerators
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
Food (vegetables, fruits) on the refrigerater side freezing
Your model has a control damper inside the vent. The damper opens and closes with changes in temperature. It has a pig tail spiral thermostat on the side and if it goes bad the door sticks open or closed. Sometimes it is just frost but you will need to get to it. I will send photos and links in a moment, Thanks Sea Breeze
Jan 20, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Refrigerater Light
Hi there check plastic angle bracket on bottom of door is not broken as it pushes the fan/light switch.Hope this helps
Dec 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Frigidaire Refrigerator Light Switch - 5303289051 Logo
191 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Sal De
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
