Question about Iron Works DCC-60 Stainless Steel
Need new burners for my gas grill - Iron Works DCC-60 Stainless Steel
  • jkokas Jul 19, 2010
    find burner for my ironworks grill
    I need to replace my Ironworks gas grill burners. Where can I find replacement parts.
    Top Expert:
  • Iron Works Master
  • 83,096 Answers
We are not a parts supply web site so we can't directly supply parts for this, we however can direct u to a web site that can get you what u need most likely, that is the only resource we have for this type of question, thanks.
Go here for parts:
http://www.appliancefactoryparts.com/gasgrillparts/brands/ironworks/
Posted on Jul 19, 2010
  • 5,081 Answers
Http://www.clagrills.com/
http://www.thebbqdepot.com/
YOu can buy the gas grills online in the above two links...
  • 360 Answers
Hi, check out this link below to find out the one you need.
http://www.clagrills.com/
Take care
Posted on Jul 18, 2010
Popping of gas from new burners and going off and on
check to see if there is any packing in the burners , they could be just not in the right postion or the air mix could need adjusting .
Apr 20, 2012 | Brinkmann Charmglow 810-7400-S Propane...
New natural gas grill will not start. What are we doing wrong?
Is the inline gas shut shutoff valve, that's required by code, turned ON? Are you sure you're getting any gas to the grill? Have you tried to match light one burner to test it? That's where you need to start your trouble shooting.
Also, don't go by what it said on the box it came in. Check the manufacturer's tag on the grill to make sure it is in fact, a Natural Gas Grill. If it's propane, nothing you do will get it to light. Sometimes the wrong things get in the wrong boxes.
Mar 08, 2011 | Barbeques Galore Turbo Elite 4-Burner with...
Looking for replacement parts for SPG90B Campcheif Big Gas 3
I looked around online and could not find anything for my gas grill. My burners all disentergrated. I found Walmart is a good source for cheap generic grill parts but only at certain times of the year. I recently replaced 3 burners on my gas grill. The new burners were build like a trombone so one size fits any grill. The metal looks a lot better than the original equipment. At $10 a burner I am back in action!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 29, 2010 | Camp Chef Big Gass III - SPG-90B Grill
Gas will not flow to burner to light grill?
could be the reg on the tank , not working no flow of gas ,
May 15, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
The new style OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
Mar 28, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Grill mysteriously not working, gas tank full, can't smell or hear gas come to burner
Go to Dome Depot. Lowes or whomever your large hardware store is and get and new regulator and connecting kit (it is probably the regulator), they are not expensive. If this does not do it, it may be the valve on the broiler, but not likely.
May 01, 2009 | Grilling
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Grilling Logo
21 people viewed this question
Top Iron Works Grilling Experts
Paul Carew
Marvin
Marvin
Tom Chichester
Are you an Iron Works Grilling Expert? Answer questions, earn points and help others
