Question about HP OfficeJet J4580 All-In-One Laser Printer
Suddenly HPJ4580 has stopped printing - when pressing print the first sheet sails through the printer and out the back with no print and the second sheet jams - no matter what I do - changed paper - turned printer off and on - checked for paper jams - any ideas
I have problems with paper jams all of the time and it won't print once it jams. I turned off the printer, unplugged it, plugged it back in and turned the printer back on and it worked. You could try that.
Posted on Jul 22, 2010
Replaced black ink cartridge, but now it only prints a very faint line, cant make out what is printing
Sir/Madam
If your printed pages have a horizontal line in the text or graphics (as shown in the illustration below) or blank text, some of the nozzles may be clogged and need to be cleaned
Go to Section 2 for instructions on how to print the Alignment Check sheet and adjust the print alignment.
Section 1: Checking the print quality and cleaning the print head
  1. Print a Print Quality Check Sheet.
    1. Press Menu.
    2. Press the UP OR DOWN ARROW key or the dial pad to choose Ink Management and press OK.
    3. Press the UP OR DOWN ARROW key or the dial pad to choose Test Print and press OK.
    4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and pressOK.
    5. Press Color (Colour) Start. The machine begins printing the Print Quality Check Sheet.
  2. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  3. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
    (A) One or more complete blocks of colors are missing:
(B) Most of the short diagonal lines are missing from one or more color blocks:
(C)Some parts of the short diagonal lines are missing from one or more color blocks:
  1. The display will then ask you if the print quality is OK for black. Press the DOWN ARROW key or 2 to choose Nofor black with the problem.
  2. The display will then ask you if the print quality is OK for Color. Press the DOWN ARROW key or 2 to chooseNo for color with the problem.
  3. The display will then show Start Cleaning? Yes No.
    Press the UP ARROW key or 1 to choose Yes and the machine will start cleaning the color ink cartridges.
  4. When the machine completes cleaning the print head, press Color (Colour) Start. Another Print Quality Check Sheet will print.
  5. Repeat the cleaning and the quality check process following the Step 4-7.
  6. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
9. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you do not see any improvement on the second or third Check Sheet, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (A) or (B) and you see some improvement on the second or third Check Sheet but it's not perfect, repeat the cleaning and the quality check process three more times (totally five times). If you do not see any further improvement after that, please contact Brother Customer Service from "Contact Us."
  • If the print quality on the first Check Sheet matched Example (C) and you do not see any improvement on the second or third Check Sheet, repeat the cleaning and the quality check process three more times (totally five times). If you still do not see any improvement, please contact Brother Customer Service from "Contact Us."
10. Press Stop/Exit.
Section 2: Checking the Print Alignment
  1. Press Menu.
  4. Press the UP OR DOWN ARROW key or the dial pad to choose Print Quality/Alignment and press OK.
  5. Press Black (Mono) Start or Color (Colour) Start. The machine begins printing the Alignment Check Sheet.
  6. By reviewing this Check Sheet, you can determine if the alignment needs adjustment.
  7. Examine the 600 dpi and 1200 dpi test prints on the Alignment Check Sheet. If the number 5 sample of both the 600 dpi and 1200 dpi most closely matches the 0 sample, press the UP ARROW key or 1 to choose Yes.
    If one of the other samples is a better match for the 0 sample, press the DOWN ARROW key to choose No. The display will then prompt you to choose the sample that most closely matches the 0 sample for 600 dpi and then 1200 dpi.
  8. Press Stop/Exit.
If the print quality continues to be poor, go to Section 1 to clean the print head.
If your question was not answered, please check...
Improve poor print quality Brother
Or
If You Still need Brother Printer Help then I suggest You follow Us On For: Brother Printer Support
Oct 09, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
IP Address Not Printing
use its utility to configure ip address
Oct 17, 2017 | Star Micronics TSP100 Thermal Printer
The colour not sharp and got vertical line when print
A reason for the non-sharp collorcould be that the ink is not dried correctly, so open the printer settings andclick at the Slow Drying Paper in the Basic tab. Thus, theprinter will let the paper to dry better.
Regarding the vertical line (and not sharp color) we could check the printquality and then align the nozzles:
Checking the print quality: 1. Print a Print Quality Check Sheet.a. Press the Ink or InkManagement key on the control panel of the machine.b. Press the up or down arrow keyto choose Test Print and press OK. c. Press the up or down arrow keyto choose Print Quality and press OK. d. Press Color (Colour) start.The machine begins printing the Print Quality Check Sheet. 2. Closely examine the Print QualityCheck Sheet. Each of the four colors is represented by a slanted square patternmade up of individual blocks. The colors should appear in the following orderfrom left to right: Black - Yellow - Cyan - Magenta. 3. Compare the print quality of theCheck Sheet you just printed with the three examples listed below:
(B) Most of the short diagonal lines are missing from one or more colorblocks
(C)Some parts of the short diagonal lines are missing from one or more colorblocks4. The display will then ask you if theprint quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem. 5. The display will then ask you if theprint quality is OK for Color. Press down the arrow key or 2 or "-" to choose No for color with the problem. 6. The display will then show StartCleaning? Yes No.
Press the up arrow key or 1 or "+" to choose Yes andthe machine will start cleaning the color ink cartridges. 7. When the machine completes cleaningthe print head, press Color(Colour) Start. Another Print Quality CheckSheet will print. 8. Repeat thecleaning and the quality check process following the Step 4-7. 9. Compare thesecond or third Print Quality Check Sheet with the first one you printedin step1:o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you do not see anyimprovement on the second or third Check Sheet, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (A) or (B) and you see some improvementon the second or third Check Sheet but it's not perfect, repeat thecleaning and the quality check process three more times (totally five times).If you do not see any further improvement after that, please contact BrotherCustomer Service from "Contact Us".o If the print quality on the firstCheck Sheet matched Example (C) and you do not see any improvement onthe second or third Check Sheet, repeat the cleaning and the quality checkprocess three more times (totally five times). If you stilldo not see any improvement,, please contact Brother Customer Servicefrom "Contact Us".10. Press Stop/Exit.Setting the Alignment:1. Press the Ink or InkManagement key on the control panel. 2. Press the up or down arrow keyto choose Test Print and press OK. 3. Press the up or down arrow keyto choose Alignment and press OK. 4. Press Black (Mono) or Color(Colour) start. The machine begins printing the Alignment CheckSheet. 5. By reviewing this Check Sheet,you can determine if the alignment needs adjustment. 6. Examine the 600 dpi and1200 dpi test prints on the Alignment Check Sheet. If the number 5 sampleof both the 600 dpi and 1200 dpi most closely matches the 0 sample,press the up arrow key or 1 or "+" to choose Yes.
If one of the other samples is a better match for the 0 sample, press the downarrow key or "-" to choose No. The display will thenprompt you to choose the sample that most closely matches the 0 samplefor 600 dpi and then 1200 dpi. 7. Press Stop/Exit.
Aug 04, 2011 | Brother MFC-5860CN InkJet Printer
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print head is not printing seems to be clogged from non-use. Have tried test printing through several new cartridges and still not working. Can the old - dryed ink be cleaned off of the print heads?
Hi, below is from the brother website for your model. Very common for the ink heads to become clogged /dry out. You probably have done this but here it is anyway. your print head is part of the machine, so it will need to be disassembled to clean it, That can be very difficult. Try the following anyway, it might help you. also, you could try using a Q-Tip wet with vinegar water to get under to the bottom of the print heads, if you can get the head to move off its dock and then unplug it when its moved over. anyway here is the Brother link info (without pictures-see the link above if you need the pictures)
  • Print a Print Quality Check Sheet.
    1. ress the Ink or Ink Management key on the control panel of the machine.
    2. Press the up or down arrow key to choose Test Print and press OK.
    3. Press the up or down arrow key to choose Print Quality and press OK.
    4. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
  1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
  2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
  3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to chooseNo for black with the problem.
  4. The display will then ask you if the print quality is OK for Color. Press down the arrow key or 2 or "-" to chooseNo for color with the problem.
  5. The display will then show Start Cleaning? Yes No.
    Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
  6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
  7. Repeat the cleaning and the quality check process following the Step 4-7.
  8. Compare the second or third Print Quality Check Sheet with the first one you printed in step1:
    Press Stop/Exit.
Aug 29, 2010 | Brother MFC-5460CN InkJet Printer
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Will not print test page or documents
  • Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
  • While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
  • Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
  • Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
  • Press the PAUSE button. The printer begins printing the self test.
  • To stop printing temporarily, press the PAUSE button.
  • To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Jul 04, 2008 | Office Equipment & Supplies
Card stock won't feed
HI,
SOLUTION:
  1. Perform a semi-full reset on the all-in-one by following the steps below
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them.
  6. Allow the all-in-one to re-initialize. This may take a minute or two.
  7. If prompts appear in the all-in-one display to set the front panel language and country settings, perform the steps to set this information.
  8. Insert the card back into the appropriate slot.
  9. If it does not begin to print a proof sheet automatically, press the Proof Sheet button and follow the normal process for your model to print a proof sheet.
  10. Once the proof sheet begins to print, press Cancel to stop the proof sheet from printing.
  11. Use the On button to turn the power off and then back on again.
    The problem should be corrected. If the problem still exists, service your product.
Thanks
Dec 16, 2007 | HP Photosmart 2610 All-In-One InkJet...
Cannot restore the settings of printer like the tear of on the keybord... what did do to restore the settings of this printer... i cannot print  the print out is a symbol . same on the printest on the...
To do a Default Setting Mode to an Epson LX300+, you need to:
1. Power OFF the printer (for at least 10 seconds or more);
2. Press Tear Off button while simultaneously powering ON;
3. Release button, maintain power ON, printer will print basic/default settings.
At most times, it is the parallel/printer cable that gets dislodged. loosely connected or perhaps would even require replacement.
Should you want to do a printer self-test on an Epson LX300+:
Printer's Self-Test - The built-in self test function demonstrates that the printer is working properly. You can run the test with either continuous paper or single sheets; this describes the easier way, with single sheets.
* Make sure the printer is turned off and the paper-release lever is pushed back to the single-sheet position. Raise the paper guide upright.
* While holding down the LF/FF button, turn on the printer. The PAUSE light flashes.
* Slide the left edge guide until it locks in place at the guide mark. Next, adjust the right edge guide to match the width of your paper.
* Slide a sheet of paper down firmly between the edge guides until it meets resistance. The printer loads the sheet automatically.
* Press the PAUSE button. The printer begins printing the self test.
* To stop printing temporarily, press the PAUSE button.
* To end the self test, make sure the printer is not printing. Press LF/FF to eject the sheet; then turn off the printer.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 04, 2007 | Epson LX-300 Matrix Printer
HP OfficeJet J4580 All-In-One Laser Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
