Question about KitchenAid KGRA806PSS Gas Kitchen Range
I have an architect series II gas range by KitchenAid. Shortly after purchasing it the oven door latch locked and now I cannot open the door. The oven is now of no use to me. Can yo9u please help?
    Genius:
  • 1,478 Answers
Press and hold the "Clear/Off" button on the oven until you hear a beep and the word "Off" disappears from the display. The word "Lock" will remain in the display until the door lock is disengaged, which could take up to 15 seconds. You can now use the oven as normal.
Take care.
Posted on Jul 18, 2010
F5E1 or FSE1 error code DOOR LOCKED LATCH NOT OPERATING
On this double oven, each door has it's own latch mechanism that consists of a motor, a position switch, and the door switch used to activate the cavity lights. Because the error indicated a latch failure (and the bottom door was locked), Start by cycling the power to the unit. Each time the power is removed and then applied to these ovens, both latches will lock then unlock the doors to ensure they are in the home open position. By doing so, you might be able to get the bottom oven door opened allowing me access to the latch assembly. With the latch removed, I try to begin a clean cycle so you could watch the motor operate and you will probably find that it will start to turn, but never would rotate enough to lock the door. Since the position switch was not actuated at the end of the motor operation, the F5 E1 error was again displayed. Replace the motor assembly
E
Nov 23, 2011 | KitchenAid Architect Series KEMC308KSS...
My KitchenAid Architect Series II Electric Range after I ran the self clean option the oven door will not open and the display does not light up, the top burners work just fine, tried ressetting the b
Hello Gene,
On the back of the oven is a thermal fuse that probably went outduring the sefl clean cycle,ya would need to pull the oven out and remove the back panel to test it, That thermal fuse is not resettable and must be replaced,it probably looks something like this 11_15_2011_7_41_32_pm.jpg
GENE
Nov 15, 2011 | Kitchen Ranges
Kitchen Aid Gas Range Architect Series II-self cleaned the oven; it is done the oven is cold but the door is locked and nothing works on the control panel.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | KitchenAid Kitchen Ranges
I have kenmore elite gas range 790 series getting error code f93 the oven door is locked
The F93 shows that the Maximum oven door lock time has been exceeded.
Turn off the range and turn off the AC power and wait for up to 10 mins. The door should reopen. Turn on the AC power ans see if the error persists. If it does then check the following.
1. Check the wiring between EOC & Lock Motor Micro Switch.
2. Replace the Motor Door Latch assembly if necessary.
3. Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. Lock Motor continuosly runs - if Micro Switch is open, replace Lock Motor Assembly.
6. Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
Nov 12, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F5E7 Error
First,
Disconnect the power from the oven and let it sit for at least a few minutes. Then reconnect the power and see if it unlocks.
If not you may need an oven latch replacement.
Mar 29, 2009 | KitchenAid Architect ® II KEBS208S...
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Jan 21, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
My oven is locked and I have a oven mitt inside how will it come out?
control reading door locked?? or door just stuck in locked position, try turning off hte breaker to the oven for a few secs , reset nad see of the door lock mech reeales itself. if ** you can try to put the unit into a clean cycle, and then 5-10 secs after he door "locks" press hte cancel button. both ways will cycle the door lock/latch assy
Mar 10, 2008 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KGRA806PSS Gas Kitchen Range Logo
178 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
