Question about Bosch SHU9925UC Built-in Dishwasher
Dishwater won't stop trying to drain even when door is opened
My dishwasher won't stop trying to drain even when the door is open. If I put it into regular wash mode it continues to try and drain water that is not there.
  • Lawrence H. Reid Apr 21, 2008
    Thanks, It sounds like you might be right. Where is the drain valve? Is it difficult to get to?
    Thanks again for your help!
  • the2 Dec 13, 2008
    My dishwasher drains continuously even when door is open
  • 121 Answers
The drain valve is stuck open. This is electrically operated, but may have some debris inhibiting movement. If you can physically move it (with the power off) this should repair the problem.
Posted on Apr 21, 2008
"Runs" even with door open - water drains
Unplug the dishwasher from the plug site, wait one minute and plug it back in. The computer will reset itself. It should run perfectly.
Oct 28, 2017 | Bosch SHU9915UC Dishwasher
Dishwater detergent door not working
replace the dispenser mechanism...the little solenoid inside has failed that triggers the door to open.
Feb 06, 2012 | LG LDF6810ST Stainless Steel Built-in...
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Dishwater goes from sink to bottom of dishwater
you need to tie up the drain hose under the sink above where it connects to the drain spigot to stop the sink water flowing down into dishwasher instead of the drain. A blockage in the sink drainage can also make the condition worse.
Jul 14, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
The water in my dishwater does not completely get drained
A lot of the time its the line to the garbage disposal, thats where your dishwasher drains, make sure its clear and open if you dont the diswasher cant drain like it should, if thats not it, the next step chec power to it, and change solonoid valve
Feb 17, 2010 | Dishwashers
Following the wash cycle with my Miele G464SC
sounds like you mean when the unit is running you are getting water dripping from the bottom of the door panel. if you remove the door panel at the bottom where the door hinges you will find an overflow tray which runs the width of the door. This is probably blocked with food deposits.
If not you may be using too much detergent. try running with no detergent and see if there are any leaks.if you open the door mid cycle the water level shouldn't be any higher than the bottom spray arm. hope this helps
Jan 02, 2010 | Miele 24 in. G646SC Plus Free-Standing...
Water keeps filling even if dishwater is off or if the door is open, the only way to stop it is from turning tap valve off below the sink.
Your dishwasher water fill valve is defective. Remove power from the DW. Remove the bottom toe kick panel. The water valve has the incoming water line connected to it.Remove the wires from the valve. If the water stops entering you have a bad timer. If it makes no difference you have a bad valve. The valve is a replaceable part. The timer is a replaceable part.
Dec 16, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Dishwater odor
Lots of ideas,,, Try cycling the dishwasher without dishes on the hottest setting and about 10 miutes into that cycle..stop it and add 2 ups of white vinegar to the water.. let it complete the cycle..
The problem is that standing water with food byproducts will begin to smell as they break down. Like all dishwahers, there is always a small amount of water that remains in the drain system at all times so it is important to clean the filter trap and to periodically air it out or use the white vinegar method..
Hope this helps you...
Sep 23, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
WATER IS RUNNING EVEN WHEN IT IS OFF
yes, a broken valve which is a stuck-open valve...to test, remove power and slowly open main water supply and observe...no water should flow.
Nov 07, 2007 | Bosch SHU4006 Dishwasher
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bosch SHU9925UC Built-in Dishwasher Logo
506 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
