Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Previously, I described the situation as "Blue light is on, but TV does not respond to remote power button, or manual use of power button on set..." Since then, I realized that the blue light does not come on when set is plugged-in, until either the remote or the manual switch is pushed. The blue light then stays on, but the set seems to make no further response. Where should I look for the problem?
  • 11,361 Answers
Power supply module will be the first place to look, look for bad DC filter caps, cold solder joints. Need to find out if all the output voltages are OK. Right now the standby 5vdc and the processor are partially working.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find
Posted on Jul 19, 2010
LN55C750R2FXZA Samsung LCD
What your describing is symptoms of a power surge, Many LCD Tv's are sensative to Slight fluctuation in power during rain, thunder and lightning storms, i myself was happily watching Tv through such a storm at one time, and when i went to bed the TV would not respond remotely or manually, i also disconnected the power from the wall waited for the ready light to disolve and try to turn on, unfortunatley the damage was done, a Tv Repair was nessecary and since then i now use a belkin power surge protector board for my TV and appliances......one question to you is i would guarantee you do not use a surge protection my friend......and your set will need a Tv Repair, it is not major as what is neccesary is a firmware dump on the internal memory and replace the BIOS Battery as well.
Aug 17, 2014 | Samsung UN55B8000 55 in. LCD HDTV
I have a Sony TV and purchased a RCA remote control new from Walmart (as a replacement for a Sony remote control). The RCA worked fine for 2 months until I accidentally hit the wrong button. The little...
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2008 | Computers & Internet
Sceptre 32 inch, Blue LED light comes on but no picture or sound.
The internal power supply is failing. You are having to "shock" it into operation by plugging and unplugging.
Jan 01, 2014 | Sceptre X32BV-Naga 32 in. LCD TV
Alba rdvd 1001xi will not respond to remote control or manual button, help!
The set need service. Its memory IC might be damaged. To repalce it is a skilled work. You have to disassembe the internal circuit baords out from TV.
May 09, 2012 | Televison & Video
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
How do i put the code into the remote
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed,
repeat steps with the next code. If none of the codes listed for your
device work for your device or your brand is not listed, try the Code
Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes
for your brand or if your brand is not listed, try searching for your codes by
following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR
3. Press and release the device button for the device you are
programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will
blink once then remain lit. For AUX, press AUX then the device
button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least
2 seconds between each time you press POWER. Important: You
may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The
INDICATOR LIGHT will go off.
Mar 01, 2011 | Jasco 24911 Remote Control
Emerson LCD 20" tv. Plug in tv and power light comes on but immediately starts blinking. TV does not respond to any remote buttons. TV does not switch off when 'manual' power switch on side of tv is...
that problem is caused by the digital board and the partstore has them or right from Funai they mad your set around 150 dollars and the board is located just above the mainboard
Dec 14, 2009 | Televison & Video
How do i program this remote to a mitsubishi tv?
  • Manually turn on the device you wish to scan for (e.g. TV)
  • Perform Power Scan by pressing and holding (approximately 3 seconds)the desired DEVICE MODE button TV, VCR, CBL, DVD or SAT until the status indicator light begins to blink.
  • Press and release the PWR (power) button. The status indicator light will stop blinking and stay ON at this point.
  • Press and release slowly and patiently the blue UP ( ? ) button to scan forward through the code database. To scan backward through the code database, press and release the blue DOWN ( ? ) button. Each time you press the up or down arrow, the remote will try and turn off the device (TV, VCR etc) you originally selected.
  • When the device (TV,VCR etc.) responds by shutting off, press the ENTER button. This will store the code
  • in memory and you will see three blinks of the status indicator light to confirm the code input. Be patient, there are over 100 codes to search through.
Oct 20, 2009 | Big Button TV Universal Remote
61md10 front panel controls lit uo, but the TV does not respond
With a non responsive remote that would be inpossiable you need to replace the control board inside around $100 bucks then you can have a good tv again but to get to the service menu your controll has to be working.
Aug 19, 2009 | InFocus ScreenPlay 61" Rear Projection...
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
97 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
