The laptop has a black screen. Yo9u can see it a little in a very bright light
  • 2,229 Answers
Assuming you have adjusted the brightness as far as it will go, then the backlight has burned out. Most laptops have a florescent backlight. You must either replace that or replace the screen. Another problem might be that the backlight inverter might be bac.
Posted on Jul 18, 2010
Can only faintly see black screen
inverter is bad..
if screen has a little white 2 pin jack, which plugs into a little board
then its that little board is bad .if it has one gold jack
alone and plugs in at bottom of screen , then its screen bulb bad
new screen !!!
Jan 19, 2014 | HP PAVILION G7-1219WM Laptop Screen 17.3...
Laptop is on but screen is black
Try an external screen. That will exclude the motherboard. Shine a bright light at the screen, if you can see a picture, the back light has failed.
Dec 30, 2013 | Toshiba satellite c660
Black screen on dell but i can see a little
Try connecting first to a standard monitor. This should work. Likely the inverter module ( part that provides the light behind your lcd) has broken down. Dell should be able to provide you with one!
Apr 05, 2013 | Dell Computers & Internet
I can't turn start the computer the screen is just black
Has the computer been dropped, jarred, etc. Are you getting a "ghost image" on the screen in a bright light? With little info, it could be backlighting, lose connection, monitor, ribbon cable, etc.
Dec 05, 2012 | Dell Latitude E5500 Notebook
My screen is black
Your screen is black because the light in the screen of your computer is burnt. If it's a laptop, or the light is burnt, or the memory card of the laptop got out of the place it suppose to be. If it's a desktop, then you have to ask where you bought it, and they will say if the screen light is broken or there is something else.
Dec 29, 2011 | Acer Computers & Internet
How can i fix my laptop black screen? I can hear it coming on, but no image on the screen.
Instructions Things You'll Need:
  • AC adapter
  1. 1 Check the power source. While you have presumably already attempted to turn your laptop on and off, the problem may lie with your AC power adapter. Is the power-indicator light on the adapter on? If not, your problem may lie here. However, whether or not you have a power indicator light on your adapter, consider unplugging it and plugging it into another outlet. This may turn on your laptop and take care of your blank-screen problem.
  2. 2 Check your brightness settings. While it seems like a simple oversight, the brightness on your laptop may sometimes be turned all the way down. Thus, the screen appears to be black, off or defective, when the problem is simply that the brightness is on its lowest setting. To fix the brightness, check your laptop keyboard. Most laptops have the brightness settings mapped to two keys at the top left of the keyboard, accompanied by a symbol (often a sun). Use these keys to fix your brightness, but keep in mind that some laptops require that you press the Function key at the same time as the Brightness key.
  3. 3 Check the status of your laptop battery itself. There should be a battery indicator on the laptop that is connected to the battery. This indicator is either on the bottom of the laptop or (likely) on the side. If there is no indicator, your battery itself may be the problem, and may require replacing. Keep in mind that older batteries of the nickel-cadmium variety are more likely to decharge over time and forget their initial maximum charge level; this may be a particular issue to users of older laptops.
  4. 4 Find a VGA connector and hook up your laptop to an external monitor if the above steps have not alleviated the blank-screen problem. Turn on the computer and the external monitor. Does the external monitor light up? If so, the blank screen is likely due to a video subset problem/LCD problem in your laptop.
Oct 04, 2010 | Computers & Internet
IBM T61 remains with dark blank screen but is on.
Connect it to another monitor,and see if it comes on. Your screen may be damaged.
Feb 22, 2010 | Lenovo ThinkPad T61 Notebook
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
Black screen
when problems occures with monitor is always with picture tube but some time less brightness is also reason for black screen
check brightness of your system i think it should be on maximum level and brightness is perfact so i said problem with picture tube. may be picture tube is gone...
Mar 28, 2008 | Acer Aspire 5050-3242 Notebook
Mac laptop displays minimum brightness
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Feb 23, 2008 | Apple MacBook Pro Notebook
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
