Question about Garmin Nuvi 660 GPS Receiver
New Garmin Nuvi 660 gps
Yikes! I just opened the box and the instructions are pitiful.
I received a wall charger in the box, but I can't figure out how it even connects to the Nuvi to charge the thing up.
  • Garmin Master
  • 638 Answers
Page 2 of your manual shows you that the plug goes into the bottom of the GPS unit. Turn it over and you'll see a slot for the plug.
Posted on Apr 21, 2008
Will a garmin gtm 20 charger work with a garmin nuvi 660 gps
Yes! The GTM-20 is a charger with a built-in traffic receiver. The charger plugs into the cradle for the Nuvi 660 and then the Nuvi 660 snaps into the cradle.
However to receive traffic with the GTM-20, you will need to purchase a subscription, either yearly or lifetime. The traffic receiver receives traffic information from FM radio broadcast stations, which broadcast traffic data.
Feb 23, 2014 | Garmin GPS
Garmin nuvi 660 battery will not charge from car charger
Make sure the fuse to your DC socket isn't blown. Check the fuse in the tip of the charger. When your Nuvi 660 is plugged into the cradle, you should see a yellow lightning bolt over the battery icon. If you don't see this, then your Nuvi isnt getting voltage from the car charger.
You can also have a bad cradle or charger plug that plugs into the cradle. More info can be found here:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jan 22, 2011 | Garmin Nuvi 660 GPS Receiver
When I plug in the power cord it doesn't show that it is charging. All of the maps and setting are running fine. When I power it off and power is on again with the cord attached it will not charge. I...
That simply shows that the power adapter/cord is bad. To confirm it, all you need to do is to borrow another charger then plug your garmin nuvi on it to see if it charges, if it charges, then it means what you have to replace is your charger. The former battery is not bad since it can power on and off the gps.
Solution, Get a new charger for your garmin nuvi 660 gps receiver. Am very well convinced that,replacing the charger will do the job.
Hope this piece of information helped.
Dec 22, 2010 | Garmin Nuvi 660 GPS Receiver
I keep blowing fuses in the car charger for my Garmin Nuvi 660
What happens when you replace the fuse, plug in the charger without plugging the charger into the 660? Does it blow then? If not, the 660 is damaged internally and causing the fuse to blow. If it still blows, then there is a problem in the charger.
- Jim
Nov 17, 2009 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 won't turn on; have tried the reset button and nothing
you can try removing the battery leave it to dry for like 1-2 days then replace it back or replace with entirely new battery click here for a video instruction on how to open it up
Oct 08, 2009 | Garmin Nuvi 660 GPS Receiver
My garmin nuvi 660 na is locked and i cant unlock it
There should be a small pinhole for a reset button. Press and hold this reset button for 60 seconds. Then turn the device back on.
Mar 25, 2009 | Garmin Nuvi 660 GPS Receiver
Charging doesn't display map when charging
I learned that with the unit off - hold the on button down - don't release it. A PRE-BOOT MODE message will appear at the bottom and may flash. Continue holding down the start button. The first time I did it a series of dots came on the screen and I was instructed to touch each one. After that it started as normal. I plugged into a wall charger and but git the pc and nuvi icons again. I repeated the process - holding the on button on and let the PRE-BOOT MODE appear and kept holding but this time a different message came on and then the PRE-BOOT MODE appeared again. I let it go and took the unit to my car and plugged it into the Garmin car charger and it worked as it used to - normal. However, when I plugged it back in the house to the wall charged I got the pc and nuvi icon again. It appears that I am using the wrong wall charger as a previous writes stated. But the nuvi still worked in the car plugged into the nuvi charger. I hope this helps.
Jan 24, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 shutting off
It sounds like your battery is defective. They can be replaced. The Motorola phone cable is not wired exactly like the Garmin, and your Nuvi thinks it's connected to a PC. Radio Shack carries a charger for the Nuvi. I have one myself.
Let me know if you need additional help with your battery problem.
- Jim
Nov 15, 2008 | Garmin Nuvi 660 GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
