Question about Car Audio & Video
My wife has a 2002 For dFocus SE. The battery died and now whne we turn the car on there is the followign messgae on her CD player E.E. It is not asking for a code etc...just this. I took out the CD player pulled all teh plugs and put it back in and still the same problem...is her unit shot?
    Genius:
  • 1,478 Answers
I would advice you reset the CD player, all it needs is just for you to reset it, follow this procedure to reset your CD player,
Remove the front panel of the car CD player > Press the Reset button you will find after removing the player panel > press the button once using some thing stick > reinstall the panel. This should fix the problem.
Take care.
Posted on Jul 18, 2010
  • hrneufeld Jul 18, 2010
    How do i remove the panel? it is the stock CD/Radio player in a 2002 ford focus se.
  • Jimoh Adeleke Muyideen Jul 18, 2010
    If you can not locate the panel, there is another way to reset your CD player, open the hood on your Ford, locate and disconnect the negative battery cable from the negative
    terminal on the battery with the battery wrench. Wait until the following morning and reconnect the negative battery
    cable in reverse of how you removed it. Close the hood when done.
    Insert the ignition key and turn it to the run position. Watch your CD player to see if it reset. If it did not, take the Ford to your local
    Ford service department or automotive stereo repair shop to have the CD player repaired or replaced, depending on the extent of the damage.
    Take care.
My 2002 Dodge Ram cd Player doesnt work. My radio will work but my cd player wont. I put a cd in it and it says track 00/00 and does nothing, What should I do?
The player is shot! I have a 2002 Grand Caravan SE that had a similar situation with it when I bought it. You're better off putting in an after-market player.
Apr 29, 2012 | Cars & Trucks
2002 Lincoln LS cd player won't work after battery
Try checking all of your fuses. Quite often a fuse blows when batteries or alternators are changed. There should be a fuse box in the engine compartment and another under the dash.
Feb 12, 2012 | Alpine Car Audio & Video
CD eject error
My wife has a 2002 Escape and has a similar issue. She uses a piece of cardboard and slides into the CD slot and slightly presses the CD. In turn, the mechanism pushes the CD out.
I have had the CD player out in it's entirety, and nothing appears to be wrong.
Hope this helps.
Jun 11, 2010 | 2002 Ford Escape
Remote not working on Marantz 63cd. Tried
check the back of your marantz player, some old marantz products have a buttom at the back saying system or intermal, if it is on the system side, the remote will never works.
May 06, 2010 | Marantz CD-67 SE CD Player
The battery ran down on my wife's 2002 Honda Accord SE. I put a trickle charge on it over nite and battery is charged but the stereo doesn't work nor the alarm system (blue lite is not on). How do I...
Check for a sticker with the radio code inside the glove box. Some dealers fixed a second sticker in the owners manual. If not available, get the code from a Honda dealer, and be prepared to show VIN number, and proof of vehicle ownership.
Mar 29, 2010 | 2002 Honda Accord
My car battery died.when i put in a new my cd player stop working
If your radio is still working, then your power is OK. The Sony CD changer gets its power from the Sony Unilink cable. It is possible that it passed a power spike down to your CD player while hooking up your battery cables.
I just had a CDX-757MX just die a few days ago myself. My radio, amps, and other changers are still working. Could be an unfortunate coincidence.
Sep 09, 2009 | Sony CDX-454RF 10-Disc CD Changer
My battery died now disc player says no discs please help?
Very tricky, my suggestion is to restart the radio again see if it reads the CDs this time. Try removing the radio fuse, where all the other fuses are at. Turn the radio on without the fuse, press and hold a button for a minute just to make sure you drain the electricity from the changer. Then put the fuse back and see what happens. You can also disconnect the negative or ground from the battery wait five minutes and connect it again but this will also restart the car computer.
May 06, 2009 | 2006 Pontiac G6
2002 pontiac grand Am
Replce the Starter Relay in the Fuse Box under the Hood.
Jan 22, 2009 | 2001 Pontiac Grand Am SE
2002 dodge neon cd player problem
try put a cd in the slot and it shouldcome out
Jul 21, 2008 | 2002 Dodge Neon
Car Audio & Video Logo
23 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
