Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
26 hp briggs it is firing and full of fresh gas but wont start.
It turns over but wont attempt to start
  • 760 Answers
Well you didn't indicate what its mounted on but the basics are: spark and fuel. Pull a spark plug and make sure you get spark. If you do then it must be fuel. You can try a shot of starting fluid (small amont) into the carb, if it runs on that you know you have a fuel problem. Be sure the carb is getting fuel from the tank. Clean the carb. Maybe a carb kit. With today's fuel, you must take care of your fuel system. Use Sta-bil year round. Fuel can go bad in 60 days.
Posted on Jul 19, 2010
No fuel flow to Briggs & Stratton Intek, 18.5 hp
blow air back threw the line towards the tank you have something clogging it or you forgot to turn the fuel on
Jul 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Yard Machines 13.5 HP riding mower wont start. It turns over fast, has good spark, good gas, good filter, clean carb, just wont fire. It ran fine yesterday and i parked it last night and tried to fire it...
Hi, check that the choke is operating and make sure the plug is wet after cranking. If so replace the sparkplug as it may be breaking down under compression. Also make sure it has compression ad it may have a stuck valve. regards Phil
Jun 19, 2012 | Yard Machines 155 Torque Briggs Stratton...
Engine turns over but doesn't fire.
check it for spark then check if it is getting fuel cuz that might be the problem
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine will not fire {no spark }
Did you sand the rust off of the flywheel? where the magneto is. And did you set it right? It has to be real close to the flywheel. The thickness of two pieces of paper. And yes the pto switch will keep it from starting. If it is ingaged it wont start. Can you hear it enganging when you connect the battery? Try turning switch on and off see if it will kick in and out. With key on
May 10, 2010 | Yard Machines 155 Torque Briggs Stratton...
Lawn mower will not start
check gas tank with light is there dirt in tank? did you change fuel filter? is there spark at the spark plug? try a 2 second spurt of starting fluid in carburetor and crank does it fire?if it does then you most likely need to clean carburetor with carburetor cleaning spray, flush fuel lines with spray and swap fuel filter.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
410 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
