Question about Spectroniq PLTV3250 32 in. LCD TV
My dvd player will not work when hooked to tv. I
My dvd player will not work when hooked to tv. I am using ports on the right side when facing tv. I am using channel 3. thanks,
  • 11,361 Answers
The video connection on the side of the TV is for AV2 composite video input, you need to use the remote control SOURCE button to select the input source to AV2 to see your DVD, Yellow plug is for composite video, Red and White for the audio, please read your manual for more details.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 19, 2010
How do i connect my sony dvp-sr210p cd/dvd player to t.v.
you can use an RCA connector .just hooked up the rca cable in the video and audio port ( output ) of the dvd player and then the other end of the rca cable to the component input of the tv unit. then set the tv unit to the right input like AV1, AV2 or AV3. depending on the input that you have been plugged in the tv component input port.
Jun 25, 2012 | Televison & Video
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
I have my wii hooked up to the tv, but i cant hook my dvd player up because there isnt a second yellow plug.
Ur tv and DVD player have a S-Video connections ports holes for this wire right?Tries websites like Amazon.com,Ebay.com to buy this S-Video wire to used to do the connections for the tv and the DVD player together by this S-Video wire in tv S-Video and DVD player S-Video connections ports holes for this wire.Use the AV cable RED,WHITE same connections like ur Wii connections to get the Audio.
Nov 08, 2010 | Sanyo DP50747 50 in. Plasma TV
I dont really have a problem. I just dont know which port to hook dvd player to. I need maybe the layout of the back panal, on what goes where.
U have a lated DVD player,like less than three years old?U can hook it up with one cable wire.It call a HDMI cable.Very easy to hook up,just one end of the HDMI cable to the tv HDMI tv port hub,the other side of HDMI cable to the HDMI DVD player port hub that it.Now u,must know with HDMI hub port u put ur signal in like 1 to 4,now go to that HDMI port hub,and will find ur dvd disc picture in playing in.
Apr 26, 2010 | Mitsubishi WD-52528 52" Television
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
Problems hooking it to the television
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Jan 18, 2009 | GoVideo DV2140 DVD Player/VCR
Cable/ant. hook-up
If you have a yellow/white jack on your DVD/VCR unit you can connect it to the TV using composite cables. If you only have the coax output on the DVD player you can buy an RF modulator that will convert the coax to composite also. But if you have two ports on thhe DVD player as most combos do the top is usually an input source such as cable and the bottom is the output that goes to the back of the tv. You could also buy a "splitter" and attach the cable and dvd coaxs to each of the out ports(they will be side by side) and on the opposite end, which is the in run a coax from that port to the tv coax port.
I hope this helps you out. If you need assistance you can visit me on the chat portion of this website.
Sep 09, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up dvd
Brad, AV-1 INPUT, be advised this will use up the AV1 port so if you have another item that uses regular AV cables you`ll then have to use AV2 for the video in and L&R audio in, enjoy, BMW Rider
Jan 07, 2008 | Philips Magnavox 27MT5405 TV
At the end of my wires
If you use scart cables you almost cannot go wrong. You can either hook one scart from your DVD/VCR to the TV and one from the cable box to the TV, and switch using the A/V button on your TV.
Alternatively, you can hook one from your cable box to the "in-port" on your DVD/VCR, and one from the DVD/VCR to the TV. In this case you should be able to record programs from your tuner.
Dec 11, 2007 | Toshiba 27A44 27" TV
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Spectroniq PLTV3250 32 in. LCD TV Logo
61 people viewed this question
Top Spectroniq Televison & Video Experts
Chinmay Joshi
Chinmay Joshi
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
