Question about Hoover HCA391FFK Bottom Freezer Refrigerator
Fridge compartment not cooling ......freezer ok
    Scholar:
  • 149 Answers
Verify is in the air vent to fridge isn't obtructed by food products also there's a vent in the the freezer that if obstructed no cold air comes in.
Posted on Apr 21, 2008
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Fridge/freezer not cooling
check the door switch ok or not
if the door switch not ok replace it if ok ch the cooling cycle
Mar 16, 2014 | Siemens KG34NA13GB
Refrigerator too warm
If this is a bog-standard fridge... then its the freezer compartment which actually cools the rest of the fridge. Air needs to circulate throughout the fridge... is the freezer compartment full of ice and need defrosting... if so, do not use sharp objects as there is a thermostatic temperature sensor wire in the vicinity of the ice-box.
Mar 06, 2014 | Sanyo Refrigerators
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
I have an amana fridge model # arb190rcw.nothing remains frozen in the freezer.and i have noticed ice on the back wall of the freezer compartment
Your cooling coils have frosted so much that there is ice forming allover the cooling coils and preventing the actual cooling inthe fridge. First of all shut off the fridge for about 10 hours and wait for all the ice to defrost. Clean up your fridge well and then check inside of the freezer compartment for break in wiring, failure of the heater or the thermostat. Now put the fridge on and see if the cooling comes back.If the set works ok then dont worry till you experience the same fault coming back. In this case your auto defrost timer could be faulty as it is not doing the 8 hours cycle defrosting. Check this out test and replace . Get help if you are not familiar. good day
Jul 31, 2010 | Amana ARB190RCW Bottom Freezer...
Fridge compatment not cooling
If freezer compartment is cold and fan is working, do a 12 hour defrost and all should be ok.
May 21, 2010 | Refrigerators
My Amana fridge #ARB2215CB seems to be cooling the
Your refrigerator probably has an issue with its "damper control assembly", which regulates cold air coming from the freezer compartment. Contact an appliance service company.
Apr 13, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
Hoover HCA391FFK Bottom Freezer Refrigerator Logo
239 people viewed this question
Top Hoover Refrigerators Experts
Charles T Nevin
Charles T Nevin
Jim Goldsmith
Jim Goldsmith
JONFRIDGEDOC
Level 1 Expert
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
